gbone8106 25 Posted May 17, 2018 Posted May 17, 2018 I thought I saw in 3.4.0.0 update that HDR info details will display, I don't see it. Can someone point out where it is supposed to be?
Jdiesel 1435 Posted May 17, 2018 Posted May 17, 2018 You may need to refresh the metadata for the library item/items for the information to populate. It should show up under "Media Info" for the library item. 1
Luke 42210 Posted May 17, 2018 Posted May 17, 2018 Yes it will show up for new content, but existing content will require manual refreshes. Thanks. 1
Riggs 312 Posted May 18, 2018 Posted May 18, 2018 Yes it will show up for new content, but existing content will require manual refreshes. Thanks. I have a question about this topic. I'm working on my own complete ART for covers, logos and a few backdrops. The manual refresh have 3 options, but seems the only choice that works fine is when you check, "Replace all images" and that not work for me. My library is big. Movies only. Around 1600---1700 titles
Jdiesel 1435 Posted May 18, 2018 Posted May 18, 2018 If you go to the metadata manager in the server dashboard you can select the parent library entry then select refresh metadata from the three dot menu.
Riggs 312 Posted May 18, 2018 Posted May 18, 2018 Thank you very much @@Jdiesel I do that too but it change all, it don't respect my covers I start marking each item at hand to looked. (Hope this works) Another info about my settings. I stop usinf .nfo's because they never refresh. Now, all my libraries are setting for just pull the logo and cover art and save in the movie directory at side of the movie with the backdrop. Will see Thank you
