Emby for Kodi - Android Clients out of Sync
met4lface
Recently I noticed my android clients are out of sync. In the server dashboard, there is only 1 device listed for both clents. I'm guessing this is some sort of device ID issue. The logs I posted are after deleting the device on the server, restarting server and opening the clients one by one.
Shield 1.log
Shield 2.log
Angelblue05
Thank you for posting your logs. I'll have a look shortly.
Angelblue05
Thank you, I'll be reverting my changes to device id. I cannot find a good solution. This should bring you back to a working state. I have another small thing to validate first, before posting a new build. Thanks for your patience.
  • Like 1
Angelblue05
Test 3.0.26. Don't forget to restart Kodi. Should be back to working state.
Guest
