jonomite 29 Posted May 16, 2018 Posted May 16, 2018 Does the wake on lan function work when you're not connected to the same network as the server? Sent from my Nexus 5X using Tapatalk
softworkz 5133 Posted June 1, 2018 Posted June 1, 2018 There are NAT routers that you can configure to send a WOL packet in your LAN when there is incoming external traffic on one of the published ports. (in this case you wouldn't make use of any emby WOL feature at all)
