screwfaze 38 Posted July 9, 2018 Author Posted July 9, 2018 @@Luke I have tried converting to universal mobile and universal tv but sound is still the same as the original.
Luke 42243 Posted July 9, 2018 Posted July 9, 2018 what do you mean still the same? what exactly is it?
Luke 42243 Posted July 9, 2018 Posted July 9, 2018 So after converting that means the file is direct playing now, right?
Luke 42243 Posted July 9, 2018 Posted July 9, 2018 Ok then in that case I really think you need to try and fix this on your end via xbox & speaker settings. When it direct plays there's nothing we can do about it. The only thing we can really do is force a transcode and convert the audio to stereo, but do you really want all of your files to transcode?
screwfaze 38 Posted July 9, 2018 Author Posted July 9, 2018 Thanks Luke I will play around with the settings and see if I can solve this
FrostByte 5454 Posted July 9, 2018 Posted July 9, 2018 Other than buying a soundbar 1. If you're still using your TV speakers though make sure you have the following set on your Xbox: Settings Display & Sound Volume Setup TV & AV control Audio > Set this to stereo Settings Display & Sound Audio Output HDMI audio > set this at bitstream. Or, you could try stereo uncompressed but that may convert it to 2 channel PCM Format > Set this to Dolby Digital as most TV speakers support DD. 2. Next if your TV has the ability to set audio output format make sure it's set at DD 3. Lastly, make sure you have Emby's volume control setting set high enough. A lot of people don't know it's there Start a movie in Emby on the Xbox Click the Home button on the controller. This should bring up a menu Scroll to Emby Theater and click on it (should be the first item on menu) Now you should see a volume control slider Move this to the right Scroll down and return to Emby Theater 2
