Help setting up shield tv, avr, smart tv via ARC
vangeliis
Thanks @@CBers.
  • Like 1
Guest asrequested
Okay guys I think I can see some light at the end of the tunnel.
After switching everything off (unplugging the power cords from the sockets) and turning power back on again..........
ARC WORKS again!!!!!!!!!!!!!!!!!!!!!!
Hallelujah.
Fantastic! My next suggestion was to look at page 103, which I believe tells you to do something similar.
vangeliis
Thanks @
What the actually mean when they say turn your TV off and back on again is "unplug your TV's power cord to completely turn the TV off"
I tried the off/on/off/on but it only worked when I unplugged the cord. There is no "off" anymore just standby until you kill the power.
Guest asrequested
Gotcha! So a reboot was needed. Power cycling seems to be a universal fix, these days.
