vangeliis 8 Posted May 15, 2018 Posted May 15, 2018 (edited) Hi,I’m probably missing something very obvious but please feel free to point it out.After been fed up with the way TizenOS handles audio pass though I got myself an nvudia shield tv.The way I have configured my system is as follows:ShieldTV—> Onkyo AVR hdcp 2.2–>Samsung Tv (2017 Tizen) Hdmi3 ARC.This way the Emby Android tv app for shield tv works great and I get all the hd audio lights to come up on my avr.The only major problem I have is that the TV can’t send audio back to the avr via arc as it used to do before connecting the shield. The only option I get in the audio settings is Optical out.Is it possible to configure the arc chain so that when I’m watching liveTv the sound is not coming out of the tv speakers but through the only?Any help would be greatly appreciated.Vangeliis Edited May 15, 2018 by vangeliis
mastrmind11 722 Posted May 15, 2018 Posted May 15, 2018 yes, there is a setting on your tv to enable arc and/or disable tv speakers. this has nothing to do w/ adding the shield.
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 Hi, ARC is enabled on my TV but the only option I get is Optical out or bluetooth speaker, while before connecting the shield, I had the option for home theatre. To me it looks like the TV does not recognise the AVR is still connected.
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 Does it have something to do with the fact that the shield tv video mode is set to 4k@60fps and arc does not support it?
ebr 16334 Posted May 15, 2018 Posted May 15, 2018 Does it have something to do with the fact that the shield tv video mode is set to 4k@60fps and arc does not support it? The use of ARC for your TV should not have anything to do with the Shield if it is connected properly. Now, ARC will not be available while actually using the Shield because it isn't necessary - the Shield is directly connected to your AVR. ARC would only come into play when you are actually viewing another input (like the TV tuner itself).
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 @@ebr thanks for your comment. The way I have set it up ARC lights up on my avr. However when I change input (from shield to live tv) I only get sound from the TV speakers. For some reason the TV does not send audio to the avr via arc. Puzzling...
mastrmind11 722 Posted May 15, 2018 Posted May 15, 2018 And you're certain you have the cable plugged into the ARC port?
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 thanks @@mastrmind11 100%. it's HDMI3 on my MU6470.
Guest asrequested Posted May 15, 2018 Posted May 15, 2018 I'm curious. Are you trying to return audio after the stream has passed through the AVR? If that's the case, there isn't any audio. The AVR should only output video, as it is designed to process the audio.
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 @ No, I'm trying to return audio when watching terrestrial TV.
Guest asrequested Posted May 15, 2018 Posted May 15, 2018 @@ebr thanks for your comment. The way I have set it up ARC lights up on my avr. However when I change input (from shield to live tv) I only get sound from the TV speakers. For some reason the TV does not send audio to the avr via arc. Puzzling... So you're watching a different source of media, that is directly connected to the TV, in a another HDMI port? The way you have it connected, that is what it's designed for. What exactly are you trying to accomplish?
Guest asrequested Posted May 15, 2018 Posted May 15, 2018 @ No, I'm trying to return audio when watching terrestrial TV. Oh right, so the tv tuner is in the tv, and you have an antenna connected to the TV?
Guest asrequested Posted May 15, 2018 Posted May 15, 2018 (edited) According to the manual, you have to disable the tv speakers. That you can hear sound from the tv, would suggest you haven't done that. Edited May 15, 2018 by Doofus
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 Can't find how to disable the TV speakers. I have attached my TV's manual. UE40MU6470.pdf
Guest asrequested Posted May 15, 2018 Posted May 15, 2018 It should be under Settings > Sound Sound > Output Page 78
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 I only have two options: Optical out Bluetooth speaker.
CBers 7554 Posted May 15, 2018 Posted May 15, 2018 I have my Shield connected to my LG soundbar for audio, with the video going to the ARC port. I get sound to the soundbar if I use the TV tuner, XB1 or TV STB. Not sure what's wrong with your setup @@vangelis, but it might be worth unplugging everything and starting again. @@FrostByte is a Samsung user, so he might know how to disable the TV speakers. I had it set up on my Samsung previously, but I've migrated to an LG TV now.
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 thanks @@CBers I have just disconnected my shield and tried to go back to my previous setup and to my surprise I can't get ARC to work TV HDMI3(ARC) --> AVR Out, Anynet+ and Onkyo ARC enabled. What is going on?
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 Okay guys I think I can see some light at the end of the tunnel. After switching everything off (unplugging the power cords from the sockets) and turning power back on again.......... ARC WORKS again!!!!!!!!!!!!!!!!!!!!!! Hallelujah. 1
FrostByte 5453 Posted May 15, 2018 Posted May 15, 2018 (edited) My setup isn't exactly like this, but I guess my Xbox One X is acting sort of like your guy's Shield Xbox One X >>> Audio passthrough to HDMI input of soundbar >>> Samsung Soundbar <<< Audio from TV/ 4K from Xbox One X passthrough using ARC >>> Samsung QLED I didn't have to turn off the speakers from my TV. The TV recognized my soundbar and automatically switched audio to that. However, I can switch the audio setting of the TV back to the TV speakers if I want. Edit: my soundbar passes 4K video, some of the older soundbars do not passthrough 4K Edited May 15, 2018 by FrostByte 1
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 Thanks @@FrostByte Everything works as designed (even volume control) now after a hard restart. I knew there was something obvious missing but I did not expect that I would have to shut everything down to make it work. So relieved. Thanks guys for all the support.
FrostByte 5453 Posted May 15, 2018 Posted May 15, 2018 Great, ya I probably had all mine powered off when I hooked it up so it just configured everything and worked when I powered up
vangeliis 8 Posted May 15, 2018 Author Posted May 15, 2018 Yes, in hindsight I should have done the same. Lesson leant.
