cochize1 55 Posted April 10, 2019 Posted April 10, 2019 (edited) I understand. But it takes like 30 seconds to create a certificate. After my Emby setup I have been doing this for my office for multiple host at multiple locations so very nice. But based on your error you may need a unique fully qualified name with a "host" as part of your fully qualified name. Just don't know what what to do at this point. As you mentioned above I've been trying to use 'www' and also I have option to set a sub-domain in my domain provider. Also I have read somewhere on Let's Encrypt forum that the domain has to point to your Synology device which would be correct in my case after disabling port forwarding the address directs me to port 5000, but still all to no avail. EDIT: Haha, I just wanted to make you a printscreen to prove it is not working... and it worked:) So, what now? Edited April 10, 2019 by cochize1
d21mike 2 Posted April 10, 2019 Posted April 10, 2019 Just don't know what what to do at this point. As you mentioned above I've been trying to use 'www' and also I have option to set a sub-domain in my domain provider. Also I have read somewhere on Let's Encrypt forum that the domain has to point to your Synology device which would be correct in my case after disabling port forwarding the address directs me to port 5000, but still all to no avail. EDIT: Haha, I just wanted to make you a printscreen to prove it is not working... and it worked:) So, what now? You now have to configure your domain. You should make sure you have properly setup Reverse Proxy per the instructions here. Very important to follow the instructions. Your most resent was setup wrong. Once setup correctly you want to set *:8921 for your www.heisenberg.pl. Then you want make sure you port forward 8921 to your NAS. Then from outside use https://www.heisenberg.pl:8921 to reach Emby.
cochize1 55 Posted April 10, 2019 Posted April 10, 2019 I thought it was set up exactly as described here, in attached pic it is wrong? I thought the outcome will be that I won't need to write a port number in the browser, just the domane name and be connected through https? Basically that was the whole point...
d21mike 2 Posted April 10, 2019 Posted April 10, 2019 I thought it was set up exactly as described here, in attached pic it is wrong? I thought the outcome will be that I won't need to write a port number in the browser, just the domane name and be connected through https? Basically that was the whole point... yes. this is wrong. Look up stream and you will see the correct setup.
d21mike 2 Posted April 10, 2019 Posted April 10, 2019 After this you will need to config your certificate for the *:8921 above to use your new certificate. I believe you will see *:8921 as a option to then select the proper certificate if you do this step properly first.
d21mike 2 Posted April 10, 2019 Posted April 10, 2019 After this you will need to config your certificate for the *:8921 above to use your new certificate. I believe you will see *:8921 as a option to then select the proper certificate if you do this step properly first. If later you want a web site for you www.hei..pl then you can also associate the www certificate for that as well. But wait until you get ember working first. You already have 80, 443 and 8192 port forwarded to Synology NAS. So you url's are http://www.h..pl (default port 80) and https://www.h...pl (default port 443) and https://www.h...pl:8921 for Emby. You have to add the :8192 for Emby since it is a non-standard port.
d21mike 2 Posted April 10, 2019 Posted April 10, 2019 If later you want a web site for you www.hei..pl then you can also associate the www certificate for that as well. But wait until you get ember working first. You already have 80, 443 and 8192 port forwarded to Synology NAS. So you url's are http://www.h..pl (default port 80) and https://www.h...pl (default port 443) and https://www.h...pl:8921 for Emby. You have to add the :8192 for Emby since it is a non-standard port. BTW... You may have been wondering why you could not have used the Synology Default Certificate. I think I read that Apple product (iOS and tvOS) needed the fully qualified certificate but not sure. Anyway, cool to have your own domain certificate
craigieboy2 0 Posted April 11, 2019 Posted April 11, 2019 Hello I'm a new user installed Emby on a firestick. But it keeps saying no servers are available. Tried Emby connect but still nothing can anyone help?
Luke 42243 Posted April 11, 2019 Posted April 11, 2019 Hello I'm a new user installed Emby on a firestick. But it keeps saying no servers are available. Tried Emby connect but still nothing can anyone help? Hi there, have you setup your own emby server?
Ceten 27 Posted April 12, 2019 Posted April 12, 2019 Can't get Emby working Emby is a personal media server so it allows you to organise, play and stream your own media files. This means you need to setup your own server or be invited by someone who has a server to connect to theirs. See here for more info: https://github.com/MediaBrowser/Wiki/wiki/Quick-start
Gert-Jan Albers 0 Posted April 28, 2019 Posted April 28, 2019 No settings on the Emby side, actually - which is the nice part. Only the Synology. The source is what you're going to actually connect via https to whatever IP or dns name your synology is. I pickup port 8921 because it was available and it was "one up" from Emby's preferred https port. I'm not using Emby's secure port, but if I wanted to play with that in the future, I didn't want to use the same one and have a conflict. Destination 8096 is Emby's default http unsecured port. Lets say my Synology's IP is 10.0.1.100 When you connect, you'll use https://10.0.1.100:8921 - the Synology will automatically reverse proxy that to Emby. Hopefully your Synology is behind a firewall, so you'll need to allow port 8921 connections from the outside world if you're using Emby from outside. Don't open port 8096 as that would defeat the purpose of this. I've tested this using the androidtv & roku clients in house (not really needed), and externally on my phone with the android app as well as various browsers. I don't have an Emby Connect account, so don't know if it works that way. Ok, I got your point and it indeed works but am I correct saying that the DSM Emby App link and both links available in the Emby dashboard became invalid?
majorsl 23 Posted April 28, 2019 Posted April 28, 2019 Ok, I got your point and it indeed works but am I correct saying that the DSM Emby App link and both links available in the Emby dashboard became invalid? No, not really. You should be able to still use those links within your LAN, at least I can. The main purpose for me was to only open up just 8921 on my router/firewall, so when I'm away from home, the apps on my phone, or when using the web with my web browser are using the https connection. For consistency, even though I could use the insecure ones within my LAN, I still setup my Rokus with the same.
d21mike 2 Posted April 28, 2019 Posted April 28, 2019 (edited) Ok, I got your point and it indeed works but am I correct saying that the DSM Emby App link and both links available in the Emby dashboard became invalid? I set the ... Settings ... Advanced ... Hosting ... External domain to my remote access url domain so my Links are valid. Example: In-Home (LAN) access: http://internal ipaddress:8096 Remote (WAN) access: https://external domain:8921 I port forward 8921 to my Synology NAS My ssl certificate is based on the external domain name. I did this because I wanted my Dashboard to remind me of the correct links. Edited April 28, 2019 by d21mike
Dennis Dallau 3 Posted May 6, 2019 Posted May 6, 2019 Just to double check: What about if you guys are on the road and open DSM within a browser via your secure external domain and then click the EMBY ICON in the menu? Mine still points to the http://mydomain.com:8096 and surely does not work. It only works when I manually enter the HTTPS url with the new port number. Is that correct or does it work for you? tnx
d21mike 2 Posted May 6, 2019 Posted May 6, 2019 Just to double check: What about if you guys are on the road and open DSM within a browser via your secure external domain and then click the EMBY ICON in the menu? Mine still points to the http://mydomain.com:8096 and surely does not work. It only works when I manually enter the HTTPS url with the new port number. Is that correct or does it work for you? tnx Did you read my post? Notice my 8096 link is for the local connection and does not use HTTPS. There are multiple ways to make this happen so your setup may be a bit different than what I doing. But my method works for me.
Ninko 78 Posted January 17, 2020 Posted January 17, 2020 @@CChris Does 'Emby Connect' work with your setup? I'm asking because when I try, it fails to connect. Thanks
rabbifede 0 Posted March 29, 2021 Posted March 29, 2021 On 3/3/2019 at 11:38 AM, CChris said: Thanks a lot, that walkthrough helped me having secure connection to Emby server after switching to a pfSense firewall
