help adding library content
Hello,
I'm running emby on my openmediavault (OMV) server, installed via a Docker container.  OMV has one system drive and then 4 data disks that are pooled via mergerfs.  In linux shell I can go to /sharedfolders/Media and all of my media directories and files are there in the data pool.  I can go to individual disks via /srv/<disk name>
When I go to my Media Library via 192.168.1.64:8096 and try to add a folder, I don't see /sharedfolders/ or/srv/.  I cannot add them manually either, if I type in the path and press OK I get a message saying the path cannot be found.  I can add in the network path \\192.168.1.64 but this doesn't let me narrow down where I want emby to search for files for the library.
How can I be more specific on the folders to add to the library?
It turns out that after entering in my network path and waiting for a few seconds, I can then browse/search through the folders.
Thanks for the feedback !
