7illusions 1249 Posted March 26, 2014 Posted March 26, 2014 It's a PlayTo device. Select a Movie of your choice and instead of clicking the Play-button you click the one 2 steps to the right where it says Remote. You can then select you xb1 as a playback device.
trooper11 63 Posted March 27, 2014 Posted March 27, 2014 Also, if it matters to you, you can change the name of your X1. You just need to go into the settings section under system info and you can name it whatever you like.
