massilliaman 4 Posted May 12, 2018 Posted May 12, 2018 Bonjour, depuis la dernière mise a jours (3.4.0.0) Dans mon cas, les NFO créer par emby non plus cette partie : Hello, since the last update (3.4.0.0) In my case, the NFOs don't create this part either : <fileinfo> <streamdetails> <video> <codec>h264</codec> <micodec>h264</micodec> <bitrate>5574408</bitrate> <width>1280</width> <height>536</height> <aspect>2.40:1</aspect> <aspectratio>2.40:1</aspectratio> <framerate>23.97602</framerate> <language>eng</language> <scantype>progressive</scantype> <default>True</default> <forced>False</forced> <duration>140</duration> <durationinseconds>8413</durationinseconds> </video> <audio> <codec>dts</codec> <micodec>dts</micodec> <bitrate>1536000</bitrate> <language>fre</language> <scantype>progressive</scantype> <channels>6</channels> <samplingrate>48000</samplingrate> <default>True</default> <forced>False</forced> </audio> </streamdetails> </fileinfo> Pouvez-vous m'en dire plus. Merci d'avance. Can you tell me more. Thank you in advance.
