z3ndra 7 Posted May 11, 2018 Posted May 11, 2018 hello I have a problem with the plugin : backup it can not create backup, it marks me "failed" every time. would you have a solution please. thank you
Luke 42245 Posted May 11, 2018 Posted May 11, 2018 Hi there, can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
z3ndra 7 Posted May 11, 2018 Author Posted May 11, 2018 there are several files. which should I transmit?
z3ndra 7 Posted May 11, 2018 Author Posted May 11, 2018 2018-05-12 00:10:00.004 Error Server Configuration Backup: Could not create backup directory /home/desktop/Moovix/backup server/Emby Backup - 2018-05-12 12.10.0 - Auto *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.9.87.6 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.UnauthorizedAccessException: Access to the path '/home/desktop/Moovix/backup server/Emby Backup - 2018-05-12 12.10.0 - Auto' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.UnixFileSystem.CreateDirectory(String fullPath) at System.IO.Directory.CreateDirectory(String path) at Emby.Server.Implementations.IO.ManagedFileSystem.CreateDirectory(String path) at MBBackup.ServerEntryPoint.<ExecuteBackup>d__61.MoveNext() System.UnauthorizedAccessException at System.IO.UnixFileSystem.CreateDirectory(String fullPath) at System.IO.Directory.CreateDirectory(String path) at Emby.Server.Implementations.IO.ManagedFileSystem.CreateDirectory(String path) at MBBackup.ServerEntryPoint.<ExecuteBackup>d__61.MoveNext() InnerException: System.IO.IOException System.IO.IOException: Permission denied
Luke 42245 Posted May 12, 2018 Posted May 12, 2018 Hi, you need to make sure that emby server has write access to this folder: /home/desktop/Moovix/backup server Please let us know if this helps. Thanks.
