tuvx 14 Posted May 11, 2018 Posted May 11, 2018 I am unable to add a TV Show (all seasons, from the show's details screen), or an entire season (from the season's details screen) to a playlist. The option to do so is there, the prompt to select the list is there, but it does not add. Only individual episodes are allowed to be added. This seems to be a relatively new issue, as I was able to do so a couple months ago.
Luke 42210 Posted May 11, 2018 Posted May 11, 2018 Hi, i've tested and it seems to be working just fine. What happens when you try to do this?
tuvx 14 Posted May 11, 2018 Author Posted May 11, 2018 (edited) Nothing. I choose Add to Playlist, select the Playlist from the drop down and click add. When I open the Playlist, there is nothing in it. I tried deleting the playlist and recreating; no good. I tried creating a new playlist, no good. Edited May 12, 2018 by tuvx
Luke 42210 Posted May 12, 2018 Posted May 12, 2018 Sometimes when you add a little folder the process can take a little time. Is it possible that you just weren't patient?
Luke 42210 Posted May 12, 2018 Posted May 12, 2018 Ok, please attach the information requested in how to report a problem. thanks.
