mandysdad 30 Posted May 11, 2018 Posted May 11, 2018 I noticed that when I have a TV movie, that sometimes if the file is in the TV section, the server won't find it. If it is moved into the movie section, it's fine. So, I have some TV movies in the movie section & some in the TV section. I have done some research on this and have found that the ones that work in the movie section are on the Movie DB, and vice versa for the ones in the TV section. They are on the TV DB, but not the movie DB. Just an odd thing.
Luke 42210 Posted May 11, 2018 Posted May 11, 2018 Hi, in this situation, a movie in a tv library would just get treated like any other episode, therefore it will need to be named as such, consistently with the other episodes for that series. Please let us know if this helps. Thanks.
mandysdad 30 Posted May 23, 2018 Author Posted May 23, 2018 Thanks, got it figured out. If a TV movie has multiple parts, it works fine if they are named (Show name) episode 1, 2, etc. For instance I have Steven Kings, The Stand, and it has 4 parts, so I named them The Stand 1x1 - The Stand 1x4, and all is well.
