notkaa 1 Posted May 10, 2018 Posted May 10, 2018 (edited) Hello ! How can I activate transcoding via hardware acceleration ? I choose VA API, my server is in version 3.4.1.0, and my QNAP model is TS-253 Pro All my clients are iOS or web When media is transcoding the CPU is full so I think there is no hardware acceleration thank's for your help Edited May 10, 2018 by notkaa
Luke 42240 Posted May 10, 2018 Posted May 10, 2018 Ok, then if you're running our official QNAP package from our website, VAAPI support is included. Are you doing that?
notkaa 1 Posted May 10, 2018 Author Posted May 10, 2018 It's the official QNAP Package Version 3.4.1.0 Here's the log https://www.dropbox.com/s/obo19lw0zlyqfni/Log.txt?dl=0
notkaa 1 Posted May 10, 2018 Author Posted May 10, 2018 https://www.dropbox.com/s/gbr8e74osgvcb9j/Logffmpeg.txt?dl=0
Luke 42240 Posted May 10, 2018 Posted May 10, 2018 This is mpeg4 which vaapi does not support. Try playing something where the source video is h264.
notkaa 1 Posted May 10, 2018 Author Posted May 10, 2018 I think it works. To bad for the mpeg4... https://www.dropbox.com/s/wgo6kexhktohhak/Logffmpeg2.txt?dl=0 https://www.dropbox.com/s/ornsa43utrc65bb/embyserver.txt?dl=0
OddbOd 21 Posted May 11, 2018 Posted May 11, 2018 I think it works. To bad for the mpeg4...The speed difference you are seeing is because the Westworld episode is already an H.264 bitstream, hardware acceleration is definitely not being used.
notkaa 1 Posted May 11, 2018 Author Posted May 11, 2018 So how can I test the hardware acceleration ?
Luke 42240 Posted May 11, 2018 Posted May 11, 2018 Try lowering the quality setting in the video player to force it to transcode.
notkaa 1 Posted May 11, 2018 Author Posted May 11, 2018 Hardware acceleration enable : CPU 20% Hardware acceleration disable : CPU 52%
notkaa 1 Posted May 11, 2018 Author Posted May 11, 2018 Thanks to the Emby community for the support !
