ddurdle 75 Posted May 9, 2018 Posted May 9, 2018 There are UHD, HD and SD qualities possible to select, but no method to select 720p. If I select HD, I notice transcoding tailors for 1920x1080p. But there is no way to get 1260x720p. The selections should be inline with other Emby apps where 4k, 1080p, 720p, 460p are selectable. If we want to get "technical", the choices should be UHD, FHD, HD and SD, as HD is officially 720p whereas Full HD is 1080p.
ebr 16335 Posted May 9, 2018 Posted May 9, 2018 Actually, the resolution is kind of secondary. What really matters is bitrate. Now, we do limit resolution to certain bitrates (e.g. we wouldn't try to deliver 4k at 1Mb/s). However, these options were taken directly from the other apps at the time of implementation. I guess we'll have to review to see what changes have been made elsewhere.
