AYarter 3 Posted May 8, 2018 Posted May 8, 2018 Hello: When I play x264 files that are remuxed from blu rays, or 4k files at very high bitrates the player freezes. Typically, I can watch 45 minutes to an hour before the player locks -- I get a frame every few seconds. This is a Samsung KS 8000. My Samsung UBD-k8500 player (not tizen) exhibits similar behavior, but it only shows the round circle indicating buffering, and continues on its merry way. If this is a buffer limitation, how do I fix it? If it is a player limitation, is there a player that is better suited? Adam Below is the mediainfo for the file that is giving me issues. There are two or three othere that have had issues. [adam@@Alexandria Dunkirk (2017)]$ mediainfo Dunkirk.2017.2160p.UHD.BluRay.REMUX.HDR.HEVC.DTS-HD.MA.5.1-EPSiLON.mkvGeneralUnique ID : 34248457961704849206256025357690419096 (0x19C40358CD2FA28288B6E296BDB93798)Complete name : Dunkirk.2017.2160p.UHD.BluRay.REMUX.HDR.HEVC.DTS-HD.MA.5.1-EPSiLON.mkvFormat : MatroskaFormat version : Version 4 / Version 2File size : 45.4 GiBDuration : 1 h 46 minOverall bit rate : 60.9 Mb/sEncoded date : UTC 2018-01-05 09:13:03Writing application : mkvmerge v19.0.0 ('Brave Captain') 64-bitWriting library : libebml v1.3.5 + libmatroska v1.4.8VideoID : 1Format : HEVCFormat/Info : High Efficiency Video CodingCommercial name : HDR10Format profile : Main 10@L5.1@HighCodec ID : V_MPEGH/ISO/HEVCDuration : 1 h 46 minBit rate : 58.2 Mb/sWidth : 3 840 pixelsHeight : 2 160 pixelsDisplay aspect ratio : 16:9Frame rate mode : ConstantFrame rate : 23.976 (24000/1001) FPSColor space : YUVChroma subsampling : 4:2:0 (Type 2)Bit depth : 10 bitsBits/(Pixel*Frame) : 0.293Stream size : 43.4 GiB (96%)Title : MPEG-H HEVC Video / 58221 kbps / 2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020Language : EnglishDefault : YesForced : NoColor range : LimitedColor primaries : BT.2020Transfer characteristics : PQMatrix coefficients : BT.2020 non-constantMastering display color primaries : BT.709Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2Maximum Content Light Level : 323 cd/m2Maximum Frame-Average Light Level : 144 cd/m2AudioID : 2Format : DTSFormat/Info : Digital Theater SystemsFormat profile : MA / CoreCodec ID : A_DTSDuration : 1 h 46 minBit rate mode : Variable / ConstantBit rate : 2 411 kb/s / 1 509 kb/sChannel(s) : 6 channelsChannel positions : Front: L C R, Side: L R, LFESampling rate : 48.0 kHzFrame rate : 93.750 FPS (512 SPF)Bit depth : 16 bitsCompression mode : Lossless / LossyStream size : 1.80 GiB (4%)Title : DTS-HD Master Audio / 5.1 / 48 kHz / 2411 kbps / 16-bitLanguage : EnglishDefault : YesForced : NoText #1ID : 3Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 18.9 kb/sCount of elements : 1718Stream size : 14.3 MiB (0%)Title : SDHLanguage : EnglishDefault : NoForced : NoText #2ID : 4Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 7 968 b/sCount of elements : 1432Stream size : 6.05 MiB (0%)Language : ArabicDefault : NoForced : NoText #3ID : 5Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 10.9 kb/sCount of elements : 1366Stream size : 8.26 MiB (0%)Title : Mandarin R3Language : ChineseDefault : NoForced : NoText #4ID : 6Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 16.1 kb/sCount of elements : 1310Stream size : 12.2 MiB (0%)Title : Mandarin SimplifiedLanguage : ChineseDefault : NoForced : NoText #5ID : 7Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 11.8 kb/sCount of elements : 1424Stream size : 8.92 MiB (0%)Title : CantoneseLanguage : ChineseDefault : NoForced : NoText #6ID : 8Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 14.3 kb/sCount of elements : 1416Stream size : 10.8 MiB (0%)Language : CroatianDefault : NoForced : NoText #7ID : 9Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 12.4 kb/sCount of elements : 1424Stream size : 9.45 MiB (0%)Language : CzechDefault : NoForced : NoText #8ID : 10Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 12.8 kb/sCount of elements : 1078Stream size : 9.70 MiB (0%)Language : DanishDefault : NoForced : NoText #9ID : 11Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 12.0 kb/sCount of elements : 1282Stream size : 9.07 MiB (0%)Language : DutchDefault : NoForced : NoText #10ID : 12Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 14.9 kb/sCount of elements : 1420Stream size : 11.3 MiB (0%)Language : FinnishDefault : NoForced : NoText #11ID : 13Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 10.9 kb/sCount of elements : 1296Stream size : 8.30 MiB (0%)Language : FrenchDefault : NoForced : NoText #12ID : 14Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 16.5 kb/sCount of elements : 1420Stream size : 12.5 MiB (0%)Language : GreekDefault : NoForced : NoText #13ID : 15Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 9 729 b/sCount of elements : 1424Stream size : 7.38 MiB (0%)Language : HebrewDefault : NoForced : NoText #14ID : 16Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 14.0 kb/sCount of elements : 1394Stream size : 10.6 MiB (0%)Language : HungarianDefault : NoForced : NoText #15ID : 17Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 16.9 kb/sCount of elements : 1754Stream size : 12.8 MiB (0%)Language : ItalianDefault : NoForced : NoText #16ID : 18Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 7 996 b/sCount of elements : 1402Stream size : 6.07 MiB (0%)Language : KoreanDefault : NoForced : NoText #17ID : 19Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 12.1 kb/sCount of elements : 1088Stream size : 9.14 MiB (0%)Language : NorwegianDefault : NoForced : NoText #18ID : 20Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 12.2 kb/sCount of elements : 1390Stream size : 9.24 MiB (0%)Language : PolishDefault : NoForced : NoText #19ID : 21Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 15.0 kb/sCount of elements : 1424Stream size : 11.3 MiB (0%)Title : IberianLanguage : PortugueseDefault : NoForced : NoText #20ID : 22Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 13.6 kb/sCount of elements : 1386Stream size : 10.3 MiB (0%)Language : RomanianDefault : NoForced : NoText #21ID : 23Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 14.1 kb/sCount of elements : 1292Stream size : 10.7 MiB (0%)Language : RussianDefault : NoForced : NoText #22ID : 24Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 14.0 kb/sCount of elements : 1396Stream size : 10.6 MiB (0%)Language : SwedishDefault : NoForced : NoText #23ID : 25Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 46 minBit rate : 11.7 kb/sCount of elements : 1426Stream size : 8.86 MiB (0%)Language : ThaiDefault : NoForced : NoText #24ID : 26Format : PGSCodec ID : S_HDMV/PGSCodec ID/Info : Picture based subtitle format used on BDs/HD-DVDsDuration : 1 h 45 minBit rate : 14.3 kb/sCount of elements : 1406Stream size : 10.8 MiB (0%)Language : TurkishDefault : NoForced : NoMenu00:00:00.000 : en:Chapter 100:08:51.364 : en:Chapter 200:20:13.754 : en:Chapter 300:29:07.621 : en:Chapter 400:42:35.261 : en:Chapter 500:52:48.207 : en:Chapter 601:04:32.827 : en:Chapter 701:12:50.825 : en:Chapter 801:25:55.025 : en:Chapter 901:33:23.348 : en:Chapter 1001:39:13.906 : en:Chapter 11
Luke 42241 Posted May 8, 2018 Posted May 8, 2018 Hi there, can you please attach the emby server and ffmpeg log (if there was one)? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
AYarter 3 Posted May 8, 2018 Author Posted May 8, 2018 Gere you are. There was no ffmpeg log since it was a direct play.
Luke 42241 Posted May 8, 2018 Posted May 8, 2018 Did you forget to attach the server log? If it was a direct play I'm not sure what we can really do other than suggest that you lower the in-app quality setting to force a transcode. When you attach your server log the only thing I'm really going to be looking for is any possible indication of high resource consumption on the machine so that you can turning off whatever is causing that.
AYarter 3 Posted May 8, 2018 Author Posted May 8, 2018 I could have sworn that I did. Here it is again. I don't think that ther esi a resource issue, though this machine cannot transcode 4k in real time. I'm wondering if this is a limitation of the player. Log
Luke 42241 Posted May 8, 2018 Posted May 8, 2018 I'm wondering if this is a limitation of the player. It's either that or limitation of the network connection on the TV. Server log looks fine.
SamES 1084 Posted May 8, 2018 Posted May 8, 2018 I'm inclined to suggest checking what your network/router/server load is doing when this occurs. As you mentioned, the two devices you have mentioned run different operating systems, the TV is Tizen and the player is Orsay. The Samsung player in each is similar, but not identical, so if you are seeing the same problem on both, I would be looking to network or maybe the server is struggling to keep up. 60Mb/s shouldn't be a problem for either, but worth checking. I've had both devices and haven't experienced this problem. Are you using wireless (2.4 or 5GHz, g, n or ac) or ethernet (100Mb or 1Gb)?
AYarter 3 Posted May 8, 2018 Author Posted May 8, 2018 I'm using wired 1gb ethernet. I think the TV only accepts 100 mb. The server load is 0.1 at the time, and it's always the same point in the video. My router is a frontier FIOS router, but I'm hard pressed to think that it can't hang. I could always switch out with a CISCO for some config time. It always seems to happen at the same time in the videos. It's as if there's a sudden bust in bitrate and it can't keep up. I'm just trying to confirm before I buy yet another player...
SamES 1084 Posted May 8, 2018 Posted May 8, 2018 Can you try with Wireless? I've played 80 Mb/s and higher content via wireless with no problem and it can actually sustain higher bitrates than the 100Mb interface. I use 5GHz, N-band
FrostByte 5453 Posted May 8, 2018 Posted May 8, 2018 FYI from KS8000 user manual on highest bitrate the TV itself can handle
AYarter 3 Posted May 9, 2018 Author Posted May 9, 2018 There it is. @@SamES had it. So counter intuitive -- but it works great once unplugged and on wifi. Thanks everyone! 2
AYarter 3 Posted May 9, 2018 Author Posted May 9, 2018 Upon further testing, that didn't do it. It looks like it's time to buy a shield.
SamES 1084 Posted May 9, 2018 Posted May 9, 2018 Upon further testing, that didn't do it. It looks like it's time to buy a shield. That may or not solve it, but since you have the same issue on two different devices, I suspect the cause is not the player or device.
AYarter 3 Posted May 10, 2018 Author Posted May 10, 2018 @@SamES The issue is solved. My best guess is that there is some kind of hardware commonality between the two devices, since they are Samsung. 1
SamES 1084 Posted May 10, 2018 Posted May 10, 2018 I have had both of those exact models and didn't see that problem, and to the best of my knowledge, no one else has reported this problem on the forum with a Samsung device.
SamES 1084 Posted May 10, 2018 Posted May 10, 2018 (edited) Are you enabling subtitles? Just be aware that if you do it will cause it to transcode, not DirectPlay, due to PGS subs Edited May 10, 2018 by SamES
AYarter 3 Posted May 10, 2018 Author Posted May 10, 2018 In am not enabling subtitles. This happens on a select few films, usually am hour or so in. It seems to be related to the file itself. File is direct playing. Shield does just fine. I'd be happy to supply the files in question. I suspect that it is a hardware limitation and poorly encoded files (vbr?), as I see the issues in the exact same place in plex.
SamES 1084 Posted May 10, 2018 Posted May 10, 2018 Interesting that you see it in Plex as well. You might be right about vbr, especially if it's always in the same spot. Thanks for the extra info.
FrostByte 5453 Posted May 10, 2018 Posted May 10, 2018 (edited) I suspect that it is a hardware limitation and poorly encoded files (vbr?), as I see the issues in the exact same place in plex. The mediainfo you posted above though is not a reencode, it's a straight remux from a decrypted UHD. Agree it could be hardware limitation of Samsung TV/BD players and the vbr. Edit: According to the chart I posted above your file may be maxing out the abilities of the bitrate allowed by your TV when the file is at its highest vbr peak. That is if I'm reading the chart correctly Edited May 10, 2018 by FrostByte 1
