davedick 19 Posted May 8, 2018 Posted May 8, 2018 When trying to skip thru a Emby recorded show, I noticed the following 1 Emby doesn't register if the skip button has been pressed multiple times. I need to hit skip, wait until it starts playing, and press skip again. 2 When praying skip, it takes roughly 5 to 10 seconds for a show to start playing. I don't have the convert to stream friendly format enabled I'm using a Intel 4790k with 16 GB ram. Would adding a graphics card help to speed up the process?
davedick 19 Posted May 8, 2018 Author Posted May 8, 2018 When trying to skip thru a Emby recorded show, I noticed the following 1 Emby doesn't register if the skip button has been pressed multiple times. I need to hit skip, wait until it starts playing, and press skip again. 2 When praying skip, it takes roughly 5 to 10 seconds for a show to start playing. I don't have the convert to stream friendly format enabled I'm using a Intel 4790k with 16 GB ram. Would adding a graphics card help to speed up the process? I forgot to mention, this is on a Xbox one using Emby theater.
Luke 42243 Posted May 8, 2018 Posted May 8, 2018 Mpegts can often be a difficult format for video players to handle. If you try our new feature to convert after the recording has completed I think you'll see a better result.
