serpi 82 Posted May 7, 2018 Posted May 7, 2018 Hi, since version 3.4.0, emby doesn't create anymore images for the recordings done with NextPVR. With version 3.3.x, I had to manually rescan the metadata of the recordings to get an image (with Screen Grabber). I checked the settings in the library and only activated the Screen Grabber for movie and episode images, but still no image get's created. Anything I could try? Thanks & Ciao, Alfred
Luke 42239 Posted May 7, 2018 Posted May 7, 2018 Right now it's by design. What kind of tuner do you have?
serpi 82 Posted May 7, 2018 Author Posted May 7, 2018 Right now it's by design. What kind of tuner do you have? It's a HDHomerun HDHR3-EU (dual network tuner), connected to DVB-C. I'm using NextPVR because: - I can also connect it to Kodi (and more) - I can run a script right after recordnig to convert the recordings to mp4 (and more) - I can use the EPG data provided by DVB-C without external (paid) providers How about adding an option to simply extract an image with the Screen Grabber in the picture editor? Ciao, Alfred
vaise 340 Posted May 27, 2018 Posted May 27, 2018 I have the same issue, I think I reported it somewhere a while back, cant remember where. A screengrab - or literally anything bar the current blank box would be good. Emby does not work well natively with my 3 x old HDHR Duals, Tried many times and posted in these forums my issues. I had for a time removed the plugin and just had an emby library over the nextPVR recordings - which fixes the black emty boxes, but I lose the show information etc. Iv moved back to nextPVR plugin. Mine looks like this at this moment:
vaise 340 Posted June 3, 2018 Posted June 3, 2018 server log attached. fired up roku and accessed the recorded TV plugin stuff, then did the same on the web. Missing any artwork for : toddsampsons bodyhack beauty and the beach Royal wedding (I would expect that). I personally would like anything except the blank space seen on the roku's (the web can get coloured in if you search for images however) - but I dont use the web - just the roku's. embyserver.txt
Luke 42239 Posted June 3, 2018 Posted June 3, 2018 You may want to check your next pvr log for errors.
vaise 340 Posted June 20, 2018 Posted June 20, 2018 I figured it is nextPVR not getting the artwork - I would just like anything in place of the empty space when there is no artwork found.
