Guest asrequested Posted July 10, 2018 Posted July 10, 2018 Wierd. I had the issue with a couple older ATI and NVidia cards and still have it with GT1030's I bought so I could watch my 4K remuxes as well.... Soooo frustrating. So is it only with mvc or does it affect the other 3D formats as well? I rip everything as mvc so I have nothing to test with. Other 3d formats are different
shpitz461 4 Posted July 10, 2018 Author Posted July 10, 2018 I only have MVC's, no idea if other 3D formats are broken in Theatre.
Guest asrequested Posted July 11, 2018 Posted July 11, 2018 Here's the log of a successful playback with my GTX 1050, using cuda-copy hardware acceleration. If you guys want to see?
shpitz461 4 Posted July 11, 2018 Author Posted July 11, 2018 I'm using a NUC, can't do anything about the GPU...
Guest asrequested Posted July 11, 2018 Posted July 11, 2018 I'm using a NUC, can't do anything about the GPU... I know, just thought a comparison might show something, Maybe give Luke a clue.
shpitz461 4 Posted August 26, 2018 Author Posted August 26, 2018 Still no resolution for this? Been months now...
Guest asrequested Posted August 26, 2018 Posted August 26, 2018 Yup! Still stops at that point, in Theater. I think this is another area that might benefit from my suggestions, here https://emby.media/community/index.php?/topic/46763-theater-mpv-test/?p=612780
shpitz461 4 Posted September 25, 2018 Author Posted September 25, 2018 Luke, any progress on this? MPV plays fine the same mk3d files outside of ET but freezes playback after ~26 minutes consistently when MPV is controlled by ET. I believe doofus was able to point us to the parameters difference between ET and stand-alone launching of MPV. Can we do something here? If all fails with MPV, can you provide alternatives that will provide playback resumption? Thanks!
Luke 42242 Posted September 25, 2018 Posted September 25, 2018 I'm not yet sure what we can do about it. I think this is an exceptional case. @ are you sure the mpv options were exactly the same?
Guest asrequested Posted September 25, 2018 Posted September 25, 2018 I haven't tested it, lately. I think what I need to do is see if I can make it happen in the standalone, and determine what parameter is causing it. You have a number of parameters in the playbackhandler that don't get used in the standalone. It may be to with the direct use of the hwdec via the API. I'll try hacking it again and see if I can break it, and force it to use the mpv.conf. But because each test takes 26 mins, it's a very long process, that I have to find time, for.
Guest asrequested Posted September 25, 2018 Posted September 25, 2018 But I am leaning toward the hwdec API being the issue. I've been wrestling with that, in the past. But now that I'm using auto profiles, it hasn't been so much of a concern. I've got a few ideas. I'll test them out, when I get time.
Guest asrequested Posted September 25, 2018 Posted September 25, 2018 And I'm thinking this thread should be renamed/moved?
shpitz461 4 Posted September 25, 2018 Author Posted September 25, 2018 What are you suggesting renaming it to? It's really specific to mk3d files played using internal player. Luke, would it be possible to configure all switched externally? are all the MPV switches sent by ET hardcoded? I wonder if we can try different switches and see if we can find a combination that eliminates the issue...
Guest asrequested Posted September 25, 2018 Posted September 25, 2018 Well this has nothing to do with the server, so maybe change that?
Happy2Play 9811 Posted September 25, 2018 Posted September 25, 2018 And I'm thinking this thread should be renamed/moved? To what and where?
Guest asrequested Posted September 25, 2018 Posted September 25, 2018 To what and where? Theater desktop, instead of server. And as it's a Theater issue, it probably should be over there.
Happy2Play 9811 Posted September 25, 2018 Posted September 25, 2018 Theater desktop, instead of server. And as it's a Theater issue, it probably should be over there. Done
shpitz461 4 Posted September 25, 2018 Author Posted September 25, 2018 Thanks Happy! I'll update the topic as well to specify mk3d.
Guest asrequested Posted September 29, 2018 Posted September 29, 2018 Today I'm running tests on this. I'm stripping out a whole bunch of things from the playbackhandler, that have to do with video. So far, no change. There isn't much more I can remove. No errors are being reported. It's like the stream just ends. I'm starting to think this has to do with delivery, as opposed to playback handling.
Guest asrequested Posted September 29, 2018 Posted September 29, 2018 I do see this in the server log, where it says 'unknown profile'. I don't know if that would make a difference? 2018-09-29 11:45:05.131 Info App: User policy for Peter. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2018-09-29 11:45:05.131 Info App: Profile: Unknown Profile, Path: \\Htpc\d\Temp Movie Library\Wonder Woman 3D\Wonder Woman 3D.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2018-09-29 11:45:05.131 Info App: RemoteClientBitrateLimit: 20000000, RemoteIp: 10.1.1.13, IsInLocalNetwork: True 2018-09-29 11:45:05.131 Info App: Profile: Unknown Profile, Path: \\Htpc\d\Temp Movie Library\Wonder Woman 3D\Wonder Woman 3D.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2018-09-29 11:45:05.131 Info App: RemoteClientBitrateLimit: 20000000, RemoteIp: 10.1.1.13, IsInLocalNetwork: True 2018-09-29 11:45:05.131 Info App: Profile: Unknown Profile, Path: \\Htpc\d\Temp Movie Library\Wonder Woman 3D\Wonder Woman 3D.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True
Guest asrequested Posted September 29, 2018 Posted September 29, 2018 And then, when it stops 2018-09-29 12:12:06.698 Info HttpServer: HTTP POST http://10.1.1.14:8096/emby/Sessions/Playing/Stopped. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/3.0.2 Chrome/61.0.3163.100 Electron/2.0.6 Safari/537.36 2018-09-29 12:12:06.699 Debug App: ReportPlaybackStopped PlaySessionId: 2018-09-29 12:12:06.699 Info SessionManager: Playback stopped reported by app Emby Theater 3.0.2 playing Wonder Woman. Stopped at 1588921 ms 2018-09-29 12:12:06.700 Info HttpServer: HTTP Response 204 to 10.1.1.13. Time: 2ms. http://10.1.1.14:8096/emby/Sessions/Playing/Stopped
Guest asrequested Posted September 29, 2018 Posted September 29, 2018 So it looks like the server thinks that the app just pressed 'stop', which it didn't.
Guest asrequested Posted September 29, 2018 Posted September 29, 2018 I'm testing again, to get more accurate start/stop times
