mrfaulk 10 Posted May 6, 2018 Posted May 6, 2018 is there an emby addon/extension that downloads a bunch of fan art (movie posters, backgrounds) so you can pick and choose which version you want to display? i seem to remember this sort of thing with kodi, it was really convenient tool... i do see where you can upload images from your device using the edit images function, but that's not what i'm talking about... in fact, using the emby edit image function as an example, it displays a very limited amount of fan art for each movie, is there an addon/extension that would populate this in order to give the user more choices?
Luke 42243 Posted May 6, 2018 Posted May 6, 2018 The emby image editor will display from moviedb & fanart.tv. where else do you want to pull from?
mrfaulk 10 Posted May 7, 2018 Author Posted May 7, 2018 doh, i didn't realize that if you clicked the search icon more fanart appears, in fact lots of additional fanart appears, absolutely perfect! i was a bit confused because the other front-end program i used displayed a bunch of fanart when you selected the edit button, you didn't have to select an additional button, iirc.... anyway, i like emby's function a lot more! btw, feel free to delete this post!
Luke 42243 Posted May 7, 2018 Posted May 7, 2018 What could have helped you better discover this on your own? 1
mrfaulk 10 Posted May 7, 2018 Author Posted May 7, 2018 What could have helped you better discover this on your own? a larger brain?
