joaorsfonseca 1 Posted May 6, 2018 Posted May 6, 2018 (edited) My LG tv cannot detect my Emby Server. How can I debug it? Any suggestions? Thanks. EDIT: The TV is listed on Emby's Devices list.. EDIT2: If i access url logged on app log /emby/Dlna/Profiles/0d2770285bf3386df6a5b29840193742 i get a message "Access token is required." Edited May 6, 2018 by joaorsfonseca
joaorsfonseca 1 Posted May 14, 2018 Author Posted May 14, 2018 (edited) @@Luke Log attached... EDIT After restart, Emby is now detect on my TV. Log1.txt attached Log.txt Log1.txt Edited May 14, 2018 by joaorsfonseca
joaorsfonseca 1 Posted May 15, 2018 Author Posted May 15, 2018 Yes. I always have to restart Emby to be able to access it through DLNA...
Luke 42202 Posted May 15, 2018 Posted May 15, 2018 Not necessarily. The server sends out alive messages every 60 seconds. By restarting you're having one go out right away. So if you just wait a little bit, it might show up on the TV. I have an LG TV for testing and it works just fine for me. Thanks.
joaorsfonseca 1 Posted May 16, 2018 Author Posted May 16, 2018 @@Luke I have a windows scheduled task to hibernate the windows at the end of every day. After resuming from hibernation, those alive messages are not being sent. That's why I need to restart the Emby server, the application not the windows to be able to access it from my TV.
Luke 42202 Posted May 20, 2018 Posted May 20, 2018 Ok, please try again with the next release of emby server, thanks.
joaorsfonseca 1 Posted May 21, 2018 Author Posted May 21, 2018 Thanks for your answer @@Luke. I now have the Version 3.4.1.0. That version was already released?
Luke 42202 Posted May 21, 2018 Posted May 21, 2018 Yes, please try again with the next release of emby server, thanks.
joaorsfonseca 1 Posted November 17, 2018 Author Posted November 17, 2018 Hi all.. This is not solved yet... At least for me.. I'm now running Version 3.5.3.0 and when i wake up server (using my android app)is still unavailable on my TV. I always need to do a restart the Emby server (again, on my android app) for the server be available on my TV. Log_17112018.txt
Luke 42202 Posted November 17, 2018 Posted November 17, 2018 Please try again with the next release of emby server. Thanks !
joaorsfonseca 1 Posted February 2, 2019 Author Posted February 2, 2019 Hi Luke.. I'm running now on Version 4.0.1.0 and it doesn't work yet. I've attached the two log files.. The first (embyserver-63684716392.txt) is one before i restart the server on my android app.. The second (embyserver.txt) is the one after that.. While on first file the only reference to Dlna is when it's being disposed, on the second one we have those 4 lines: 2019-02-02 14:59:57.960 Info App: Loading Emby.Dlna, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null 2019-02-02 15:01:12.734 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2019-02-02 15:01:15.087 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 2.3531346 seconds 2019-02-02 15:01:15.759 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 192.168.1.7 Thanks. embyserver-63684716392.txt embyserver.txt
joaorsfonseca 1 Posted February 5, 2019 Author Posted February 5, 2019 55UB850V-ZD Software: 05.05.75 webOS: 1.4.0-2334
Luke 42202 Posted February 13, 2019 Posted February 13, 2019 Can you try restarting Emby Server with the LG dlna app running?
joaorsfonseca 1 Posted February 13, 2019 Author Posted February 13, 2019 Can you try restarting Emby Server with the LG dlna app running? That is what i do everytime... Restart
Luke 42202 Posted February 13, 2019 Posted February 13, 2019 Ok, we're looking into improving this, thanks.
LennyLip 0 Posted July 6, 2021 Posted July 6, 2021 Version: 4.6.4.0 Issue still in place. DLNA server not showing in the network after resuming from hibernation (Windows). Need to manually restart.
Luke 42202 Posted July 6, 2021 Posted July 6, 2021 9 hours ago, LennyLip said: Version: 4.6.4.0 Issue still in place. DLNA server not showing in the network after resuming from hibernation (Windows). Need to manually restart. Hi, I'm surprised to hear this. Can you please attach the emby server log? thanks.
