Guest asrequested Posted May 7, 2018 Posted May 7, 2018 Yeah, that's what I was saying in post #9. I had the same thing on my tablet.
golfboy 2 Posted May 7, 2018 Author Posted May 7, 2018 I just included a direct stream of The Accountant. Still the same issue As devices Im using the Sony Xperia Z4 tablet and the Sony Xperia Z5 mobile phone. I dont think I could choose the app when I wanna play a movie from Emby? My mobile phone has 6.0.1 Android and my tablet has 6.0 Android @@Luke How can I provide a sample? Just by editing a little bit of the movie? Log the accountant.txt
Waldonnis 148 Posted May 7, 2018 Posted May 7, 2018 Odd, both of those devices are more than capable of playing back stuff like this. By app, I meant how you play the movie. In a web browser (and which one), the Emby mobile app, or something else like VLC or Kodi? The screenshots hinted that it's browser playback, but I'm not sure which browser you are using. The latest log is a simple remux (video and audio are just copied as-is), so if that's not playing back properly, then it's likely that the web browser or app just isn't rendering properly. I've seen similar behaviour with some Android web browsers before, but it wasn't worth the effort to look into at the time and it wasn't a big deal for what I was doing. You can try another browser if you're using a browser for playback, or maybe the Emby app to see if the behaviour is the same. The Emby app is limited to a short playback period if you haven't purchased it or don't have premiere, but it should be long enough to see if the same problem presents in the app as well.
golfboy 2 Posted May 7, 2018 Author Posted May 7, 2018 @@Waldonnis Im using the app and using the web browser. On my mobile phone its the app and tablet im using the browser with both the same issue
Guest asrequested Posted May 7, 2018 Posted May 7, 2018 It's the same problem as this https://emby.media/community/index.php?/topic/55920-video-colors-are-wrong/
Luke 42210 Posted May 7, 2018 Posted May 7, 2018 Not really because in the android app we have some potential to do something about it by configuring the video player in different ways. Web apps do not, therefore if it is really direct streaming the video then I'm not sure what we can do.
Waldonnis 148 Posted May 7, 2018 Posted May 7, 2018 It's the same problem as this https://emby.media/community/index.php?/topic/55920-video-colors-are-wrong/ Yeah, may be the same underlying cause, but solving it is problematic as Luke indicated since there aren't really any options for altering what is being used for the playback or its configuration. I tried searching some of Google's product forums and even some Android commits, but the results I keep getting are entirely unrelated or PC-centric. Sadly, I don't know much about how Android handles video and don't know where to begin to look code-wise. Unrelated note: Android seriously needs less friggin component codenames and object names that don't indicate what they do. Kodi with Embycon or the Emby Android app may be good alternatives to try on Android devices for cases like this, since both at least offer some player/renderer options.
Guest asrequested Posted May 8, 2018 Posted May 8, 2018 In my case, when my tablet updated to Android 7.1.1. it rectified the problem. Any chance of yours updating?
speedingcheetah 39 Posted May 9, 2018 Posted May 9, 2018 (edited) I helped a buddy of mine who said he videos looked like crap with he tried out Emby. (he uses Plex). I set the option to use external player setting in Emby on his Android Tablet. (dont recall what it was) Vids plays fine with MX Player Pro now. (does have the custom codec option enabled so that AC3 audio will work) Edited May 9, 2018 by speedingcheetah
Happy2Play 9802 Posted May 9, 2018 Posted May 9, 2018 I helped a buddy of mine who said he videos looked like crap with he tried out Emby. (he uses Plex). I set the option to use external player setting in Emby on his Android Tablet. (dont recall what it was) Vids plays fine with MX Player Pro now. (does have the custom codec option enabled so that AC3 audio will work) There is only one browser that supports ac3, Edge. So it is a matter of what client you are using.
speedingcheetah 39 Posted May 9, 2018 Posted May 9, 2018 (edited) There is only one browser that supports ac3, Edge. So it is a matter of what client you are using. Well.. I was referring to the Emby app and its external player support. not web browser. That being said, I play vids with ac3 audio via Opera and Chrome just fine. 90% of my media library has AC3 audio And Edge sucks in my experience. Edited May 9, 2018 by speedingcheetah
Happy2Play 9802 Posted May 9, 2018 Posted May 9, 2018 (edited) Well.. I was referring to the Emby app and its external player support. not web browser. That being said, I play vids with ac3 audio via Opera and Chrome just fine. Yes they play fine but without ac3. html5test.com will show you supported formats Edited May 9, 2018 by Happy2Play
speedingcheetah 39 Posted May 9, 2018 Posted May 9, 2018 Yes they play fine but without ac3. html5test.com will show you supported formats Irrelevant to the video color and quality issues the OP is having on his android tablet in the Emby app. My suggestion is to enable the external player app option and see if his vids play fine with MX Player Pro. If it does, then its something with Emby. If does't its that weird issues with some devices.
speedingcheetah 39 Posted May 9, 2018 Posted May 9, 2018 Yes they play fine but without ac3. html5test.com will show you supported formats for the record....Edge scores 492. Opera 520 on that html5test.com site. I do see what u are talking about though on media codec tests .
Happy2Play 9802 Posted May 9, 2018 Posted May 9, 2018 Irrelevant to the video color and quality issues the OP is having on his android tablet in the Emby app. My suggestion is to enable the external player app option and see if his vids play fine with MX Player Pro. If it does, then its something with Emby. If does't its that weird issues with some devices. Or something specific to the hardware or media being used or this would affect everyone.
golfboy 2 Posted May 9, 2018 Author Posted May 9, 2018 @@speedingcheetah I was also thinking of this but I thought there was no option to choose this. Where canni change the media player on my Android devices? Im also gonna update my devices. Didnt had time yesterday.
golfboy 2 Posted May 9, 2018 Author Posted May 9, 2018 @ I had to do 5 System updates with my mobile phone but it was worth it, the quality is now good! Gonna update my tablet tomorrow Thanks everyone for helping me out!
Guest asrequested Posted May 9, 2018 Posted May 9, 2018 (edited) @ I had to do 5 System updates with my mobile phone but it was worth it, the quality is now good! Gonna update my tablet tomorrow Thanks everyone for helping me out! What version of Android are you now on? Edited May 10, 2018 by Doofus
golfboy 2 Posted May 10, 2018 Author Posted May 10, 2018 (edited) @ I was using 7.0 Android version. (The version Emby worked perfectly) Right now Im updating again, so many updates Edited May 10, 2018 by golfboy
Waldonnis 148 Posted May 10, 2018 Posted May 10, 2018 @ I had to do 5 System updates with my mobile phone but it was worth it, the quality is now good! Gonna update my tablet tomorrow Thanks everyone for helping me out! Glad to hear it!
