ibraim 0 Posted May 6, 2018 Posted May 6, 2018 Screenshot example: Translation by Emby Translation Center: "Unable to switch audio track" Problem descriptionEmby for Android TV, in Xiaomi Mi Box 3, does not reproduces MP3 audio in ANY video file with dual audio where the codec of the first audio is MP3 and the second is AAC or AC3. Emby automatically switches to the next audio (although still reporting being on the first, watch video below). ALL video files with all other combinations described below work seamlessly (included single and dual MP3 audios):Dual AAC + AACDual AC3 + AACDual AC3 + AC3Dual MP3 + MP3 !!!Single MP3 !!!Single AACI tested approximately 70 video files to substantiate these claims.Considering this obvious relationship from the beginning, I did not analyze other variables that could be also common to all files where the problem was manifested.The same files played normally on:Emby App for Android MobileEmby Web (browser)Emby DLNA from Android Mobile app for Samsung Smart TV model 2014 Problem in action (video): https://photos.app.goo.gl/iaQxfAMsQAAZBeG89 Example of media file that presented the problem: I hope this can catch the attention of the developers and provide informations for a brief solution. P.S.: I sent two or three logs following the instructions of this page, around 7 A.M. GMT-3 through the local user "Ibraim" where the error occurred while trying to play the files "Elementary 05x08 WEB 720p Dual Dinho.mkv" and "Riverdale.S02E17.720p.WEB.DUAL.WWW.COMANDOTORRENTS.COM.mkv".
ebr 16337 Posted May 6, 2018 Posted May 6, 2018 Thanks for the detailed investigation. This should be fixed with the next release. If you'd like to test it before then, please jump on the beta for the app.
ibraim 0 Posted May 6, 2018 Author Posted May 6, 2018 Thank you @@ebr! I will install the beta. Thanks for the great app. Good job.
ibraim 0 Posted May 6, 2018 Author Posted May 6, 2018 Hello again. I installed the beta, the error message is not displayed, but the audio also does not work. The two audios are displayed, but only one is played.
ebr 16337 Posted May 6, 2018 Posted May 6, 2018 Hello again. I installed the beta, the error message is not displayed, but the audio also does not work. The two audios are displayed, but only one is played. Hi. A fix for this hasn't gone out yet. It will be in the next beta. Thanks.
ibraim 0 Posted May 6, 2018 Author Posted May 6, 2018 Oh! Excuse me. I'll be waiting. Thank you one more time.
ebr 16337 Posted May 7, 2018 Posted May 7, 2018 There is now a new beta version (1.5.84) that should fix this. Thanks.
ibraim 0 Posted May 10, 2018 Author Posted May 10, 2018 Solved! Everything was working OK already in version 1.5.8.4 and it still works in the new beta version. Thanks, thanks, thanks! P.S.: Where can I send suggestions for improvements to Emby? Which is the right place for it. Sometimes I notice some things that could get better...
ebr 16337 Posted May 11, 2018 Posted May 11, 2018 Hi. Please search the feature requests forum out here first to see if your suggestion already exists and, if not, create a post there. Thanks.
