y3knik 17 Posted May 6, 2018 Posted May 6, 2018 I have a new Live TV subscription and the guide refresh is taking really long. In the past 6 hours the refresh is now 35% complete. The refresh is only happening for 1 day so by the time the refresh finishes the day will be over! If you would like to look at the logs or the xml, I can PM those to you since my username and password are on there. Can I get some help with this please?
Luke 42244 Posted May 6, 2018 Posted May 6, 2018 What guide data provider are you using? How many channels do you have!
y3knik 17 Posted May 6, 2018 Author Posted May 6, 2018 The guide data is the one provided by the m3u stream owner. I believe the issue is that there is a lot of video on demand on the subscription and each VOD is treated as its own channel. Because of this the number is significantly inflated. If there is a way for me to filter groups of channels on the m3u to refresh then I should be ok. If not, I am open to any suggestions to help me out!
Luke 42244 Posted May 20, 2018 Posted May 20, 2018 Yes, since this isn't' really a guide, our IPTV plugin would be better suited to this. Thanks.
