loomes 40 Posted May 4, 2018 Posted May 4, 2018 With version 3.3.1.0 all is working fine. After update to newest version CoverArt wont work. Log Snippets: 2018-05-05 00:46:05.341 Info Main: Emby Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.12.0.2 64-Bit OS: False 64-Bit Process: False User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Fri Jan 12 03:39:06 UTC 2018) Processor count: 4 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin 2018-05-05 00:46:05.758 Info App: Application version: 3.4.0.0 2018-05-05 00:46:05.759 Info App: Loading assemblies 2018-05-05 00:46:05.792 Info App: Loading AutoBoxSets, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/AutoBoxSets.dll 2018-05-05 00:46:05.792 Info App: Loading CoverArt, Version=4.0.69.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/CoverArt.dll 2018-05-05 00:46:05.792 Info App: Loading Emby.Kodi.SyncQueue, Version=2.0.3.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/Emby.Kodi.SyncQueue.dll 2018-05-05 00:46:05.792 Info App: Loading MBBackup, Version=1.2.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/MBBackup.dll 2018-05-05 00:46:05.792 Info App: Loading MediaBrowser.Plugins.VuPlus, Version=3.1.7.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/MediaBrowser.Plugins.VuPlus.dll 2018-05-05 00:46:05.792 Info App: Loading statistics, Version=2.0.4.2, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/Statistics.dll 2018-05-05 00:46:05.792 Info App: Loading Trakt, Version=3.1.7.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/Trakt.dll 2018-05-05 00:46:05.793 Info App: Loading MediaBrowser.Api, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading MediaBrowser.WebDashboard, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading MediaBrowser.Model, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading MediaBrowser.Common, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading MediaBrowser.Controller, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading MediaBrowser.Providers, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading Emby.Photos, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading Emby.Server.Implementations, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading MediaBrowser.LocalMetadata, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading MediaBrowser.XbmcMetadata, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading MediaBrowser.Server.Mono, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.793 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-05 00:46:05.858 Info SqliteUserRepository: Sqlite version: 3.23.1 2018-05-05 00:46:05.859 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-7.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_LOAD_EXTENSION,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_STMTVTAB,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,HAVE_ISNAN,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,SOUNDEX,TEMP_STORE=1,THREADSAFE=1 2018-05-05 00:46:08.540 Info App: Starting entry point CoverArt.ServerEntryPoint 2018-05-05 00:46:08.543 Info CoverArt: CoverArt plugin not supported on this system. 2018-05-05 00:46:08.585 Info App: Entry point completed: CoverArt.ServerEntryPoint. Duration: 0.045185 seconds 2018-05-05 00:47:40.387 Error App: ServerEntryPoint.Instance.CoverArtImageProcessor should not be null 2018-05-05 00:47:40.389 Error HttpServer: Error processing request *** Error Report *** Version: 3.4.0.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.12.0.2 64-Bit OS: False 64-Bit Process: False User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Fri Jan 12 03:39:06 UTC 2018) Processor count: 4 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.NullReferenceException: Object reference not set to an instance of an object at CoverArt.API.ImageHandler.Get (CoverArt.API.ImageRequest request) [0x00054] in <ecb23a74c2084ff283e50b055faa0177>:0 at (wrapper dynamic-method) System.Object:lambda_method (System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceExecGeneral.Execute (System.Type serviceType, MediaBrowser.Model.Services.IRequest request, System.Object instance, System.Object requestDto, System.String requestName) [0x00076] in <5dcc71ee105a46ae808df98663db5dea>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00054] in <5dcc71ee105a46ae808df98663db5dea>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__13.MoveNext () [0x00161] in <5dcc71ee105a46ae808df98663db5dea>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__70.MoveNext () [0x006d9] in <5dcc71ee105a46ae808df98663db5dea>:0 System.NullReferenceException at CoverArt.API.ImageHandler.Get (CoverArt.API.ImageRequest request) [0x00054] in <ecb23a74c2084ff283e50b055faa0177>:0 at (wrapper dynamic-method) System.Object:lambda_method (System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceExecGeneral.Execute (System.Type serviceType, MediaBrowser.Model.Services.IRequest request, System.Object instance, System.Object requestDto, System.String requestName) [0x00076] in <5dcc71ee105a46ae808df98663db5dea>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00054] in <5dcc71ee105a46ae808df98663db5dea>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__13.MoveNext () [0x00161] in <5dcc71ee105a46ae808df98663db5dea>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__70.MoveNext () [0x006d9] in <5dcc71ee105a46ae808df98663db5dea>:0
Luke 42246 Posted May 4, 2018 Posted May 4, 2018 Hi there, can you please attach the complete emby server log? What OS are you on and how did you update to 3.4?
loomes 40 Posted May 4, 2018 Author Posted May 4, 2018 (edited) Its an Debian Testing 32Bit I updatet by manual replace the Files in /usr/lib/emby-server/bin with the mono zip from https://github.com/MediaBrowser/Emby.Releases Normaly i update over http://download.opensuse.org/repositories/home:/emby/Debian_Next/ but there is only version 3.3.1.0 at the moment. I can open the CoverArt Settings in the Admin Panel and can change settings but he dont display any preview Pictures for Treatments or overlays. When i go back to version 3.3.1.0 all is working fine. server.txt Edited July 20, 2018 by Luke
Solution Luke 42246 Posted May 4, 2018 Solution Posted May 4, 2018 The zip file contains three or four files with .config extensions. I am guessing you overwrote everything however those files should not be overwritten. Without those, imagemagick is going to fail to load and so will cover art because it can't do anything without image magick. 1
loomes 40 Posted May 4, 2018 Author Posted May 4, 2018 Ohhh im an Idiot Thats it. I reinstalled 3.3.1.0 from the repository and copied the new Version without the .config files and all is working. Thank you for the super fast support.
Nikotine 0 Posted July 26, 2018 Posted July 26, 2018 Hello, I am on Debian 9 64bit. I update by manual replace the Files in /usr/lib/emby-server/bin with the mono zip (without config files): https://github.com/MediaBrowser/Emby/releases Emby.Mono.zip (3.5.0.0) It works fine for update 3.3.1 to 3.4. But it does not worf for me for update 3.4 to 3.5 Anyone can help me please?
Luke 42246 Posted July 27, 2018 Posted July 27, 2018 Hi there, can you please describe what "does not work" means? Thanks !
Nikotine 0 Posted July 27, 2018 Posted July 27, 2018 Hi, Thanks for your reply. When I update 3.4 to 3.5. I don't have access to the web interface. I replace the Files in /usr/lib/emby-server/bin with the mono zip from https://github.com/M...r/Emby/releases Is it a good way to upgrade? When i go back to version 3.4.0.0 all is working fine. Sorry for spelling, I am a native french speaker...
Luke 42246 Posted July 27, 2018 Posted July 27, 2018 I don't have access to the web interface. What happened when you tried to access the web interface? What version of mono do you have installed?
Nikotine 0 Posted July 29, 2018 Posted July 29, 2018 - When I try to acces the web interface: timeout bad gateway I use Mono JIT compiler version 4.8.1. I update wit Emby.mono (3.5.0.0) I will retry.
Nikotine 0 Posted July 29, 2018 Posted July 29, 2018 After update Emby 3.4 to 3.5 with this methot. emby-server startInfo Main: Emby Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.9.0.6 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Sun Jul 15 19:36:19 UTC 2018) Processor count: 8 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/binappHost.InitInfo App: Application version: 3.5.0.0Info App: Loading assembliesInfo App: File /var/lib/emby-server/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0Info App: File /usr/lib/emby-server/bin/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0Info App: File /var/lib/emby-server/plugins/IMVDb.dll has version 1.0.1.0Info App: File /usr/lib/emby-server/bin/plugins/IMVDb.dll has version 1.0.1.0Info App: File /var/lib/emby-server/plugins/OpenSubtitles.dll has version 1.0.2.0Info App: File /usr/lib/emby-server/bin/plugins/OpenSubtitles.dll has version 1.0.2.0Info App: Loading Emby.Server.CinemaMode, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/Emby.Server.CinemaMode.dllInfo App: Loading IMVDb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/IMVDb.dllInfo App: Loading OpenSubtitles, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/OpenSubtitles.dllInfo App: Loading MediaBrowser.Api, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.WebDashboard, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Model, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Common, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Controller, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Providers, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Photos, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.Implementations, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.LocalMetadata, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Notifications, Version=1.0.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.XbmcMetadata, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Server.Mono, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.Sync, Version=3.5.0.0, Culture=neutral, PublicKeyToken=nullCould not load signature of Emby.Server.Implementations.Library.LibraryManager:Sort due to: Could not resolve type with token 010001ab assembly:mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 type:System.ValueTuple`2 member:<none>Error Main: UnhandledException *** Error Report *** Version: 3.5.0.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.9.0.6 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Sun Jul 15 19:36:19 UTC 2018) Processor count: 8 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.TypeLoadException: Could not load type 'Emby.Server.Implementations.Library.LibraryManager' from assembly 'Emby.Server.Implementations, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null'. at Emby.Server.Implementations.ApplicationHost.Init () [0x000a7] in <2ffcef5e7afa4820adabddd39d6ca745>:0 at MediaBrowser.Server.Mono.MainClass.RunApplication (Emby.Server.Implementations.ServerApplicationPaths appPaths, MediaBrowser.Model.Logging.ILogManager logManager, Emby.Server.Implementations.StartupOptions options) [0x000c2] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x0009c] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0 System.TypeLoadException at Emby.Server.Implementations.ApplicationHost.Init () [0x000a7] in <2ffcef5e7afa4820adabddd39d6ca745>:0 at MediaBrowser.Server.Mono.MainClass.RunApplication (Emby.Server.Implementations.ServerApplicationPaths appPaths, MediaBrowser.Model.Logging.ILogManager logManager, Emby.Server.Implementations.StartupOptions options) [0x000c2] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x0009c] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0UnhandledExceptionSystem.TypeLoadException: Could not load type 'Emby.Server.Implementations.Library.LibraryManager' from assembly 'Emby.Server.Implementations, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null'. at Emby.Server.Implementations.ApplicationHost.Init () [0x000a7] in <2ffcef5e7afa4820adabddd39d6ca745>:0 at MediaBrowser.Server.Mono.MainClass.RunApplication (Emby.Server.Implementations.ServerApplicationPaths appPaths, MediaBrowser.Model.Logging.ILogManager logManager, Emby.Server.Implementations.StartupOptions options) [0x000c2] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x0009c] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0System.TypeLoadException at Emby.Server.Implementations.ApplicationHost.Init () [0x000a7] in <2ffcef5e7afa4820adabddd39d6ca745>:0 at MediaBrowser.Server.Mono.MainClass.RunApplication (Emby.Server.Implementations.ServerApplicationPaths appPaths, MediaBrowser.Model.Logging.ILogManager logManager, Emby.Server.Implementations.StartupOptions options) [0x000c2] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x0009c] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0I do something wrong, but I don't know what...
Nikotine 0 Posted July 29, 2018 Posted July 29, 2018 I am an idiot! Luke, Thank you for your support. I understand your question. Mono-based releases now require mono 5.4+ to run... I update mono to Mono JIT compiler version 5.12.0. All works fine. Thanks you.
Luke 42246 Posted July 29, 2018 Posted July 29, 2018 @@Nikotine, Emby Server 3.5 now requires mono 5.4+, so you will need to update that since you currently only have 4.8.1. Please let us know if this helps. Thanks.
adilei 0 Posted March 4, 2019 Posted March 4, 2019 (edited) Hi Guys, I've also manually upgraded to 3.5.0.0 by copying the contents of mono.zip, after having upgraded to mono 5.18.0.268. When starting emby-server on my ubuntu machine, emby seems to go into a "loop", as partial log files are continuously written, but it never really starts up (web interface address says "cannot be reached"). Edit: based on syslog it looks like emby is crashing and respawning, however I'm not seeing the crash/exception in the logs: Mar 4 22:24:14 media-server kernel: [3058945.305366] init: emby-server main process ended, respawning Edit #2: trying to run emby from command line shows that it's not able to locate the sqllite binaries? Unhandled Exception: System.DllNotFoundException: libembysqlite3.so.0 at (wrapper managed-to-native) SQLitePCL.SQLite3Provider_sqlite3+NativeMethods.sqlite3_libversion_number() at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_libversion_number () [0x00000] in <3ba88cd71c374f278501a1db4b226935>:0 at SQLitePCL.raw.SetProvider (SQLitePCL.ISQLite3Provider imp) [0x00008] in <724f9a22df504a05b4645fb690570b7a>:0 at MediaBrowser.Server.Mono.MainClass.SetSqliteProvider () [0x00005] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x0000a] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0 [ERROR] FATAL UNHANDLED EXCEPTION: System.DllNotFoundException: libembysqlite3.so.0 at (wrapper managed-to-native) SQLitePCL.SQLite3Provider_sqlite3+NativeMethods.sqlite3_libversion_number() at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_libversion_number () [0x00000] in <3ba88cd71c374f278501a1db4b226935>:0 at SQLitePCL.raw.SetProvider (SQLitePCL.ISQLite3Provider imp) [0x00008] in <724f9a22df504a05b4645fb690570b7a>:0 at MediaBrowser.Server.Mono.MainClass.SetSqliteProvider () [0x00005] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x0000a] in <6ecbc9e0c5a4459cb6198c00e242f85d>:0 I do seem to have the binary here: /usr/lib/emby-server/i386-linux-gnu/libembysqlite3.so.0 Otherwisr, the many (unhelpful) logs files that are written contain the following (server.txt): 2019-03-04 22:18:22.296 Info Main: Emby Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.2.0.35 64-Bit OS: False 64-Bit Process: False User Interactive: False Mono: 5.18.0.268 (tarball Thu Feb 28 15:29:17 UTC 2019) Processor count: 2 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin 2019-03-04 22:18:23.571 Info App: Application version: 3.5.0.0 2019-03-04 22:18:23.575 Info App: Loading assemblies 2019-03-04 22:18:23.592 Info App: File /var/lib/emby-server/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 2019-03-04 22:18:23.592 Info App: File /usr/lib/emby-server/bin/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 2019-03-04 22:18:23.592 Info App: File /var/lib/emby-server/plugins/IMVDb.dll has version 1.0.1.0 or server-63687334758.txt: 2019-03-04 22:19:15.980 Info Main: Emby Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.2.0.35 64-Bit OS: False 64-Bit Process: False User Interactive: False Mono: 5.18.0.268 (tarball Thu Feb 28 15:29:17 UTC 2019) Processor count: 2 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin 2019-03-04 22:19:17.241 Info App: Application version: 3.5.0.0 2019-03-04 22:19:17.245 Info App: Loading assemblies 2019-03-04 22:19:17.260 Info App: File /var/lib/emby-server/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 2019-03-04 22:19:17.261 Info App: File /usr/lib/emby-server/bin/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 2019-03-04 22:19:17.261 Info App: File /var/lib/emby-server/plugins/IMVDb.dll has version 1.0.1.0 2019-03-04 22:19:17.261 Info App: File /usr/lib/emby-server/bin/plugins/IMVDb.dll has version 1.0.1.0 2019-03-04 22:19:17.262 Info App: File /var/lib/emby-server/plugins/OpenSubtitles.dll has version 1.0.2.0 2019-03-04 22:19:17.262 Info App: File /usr/lib/emby-server/bin/plugins/OpenSubtitles.dll has version 1.0.2.0 2019-03-04 22:19:17.279 Info App: Loading Emby.Kodi.SyncQueue, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/Emby.Kodi.SyncQueue.dll 2019-03-04 22:19:17.279 Info App: Loading Emby.Server.CinemaMode, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/Emby.Server.CinemaMode.dll 2019-03-04 22:19:17.279 Info App: Loading IMVDb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/IMVDb.dll 2019-03-04 22:19:17.280 Info App: Loading OpenSubtitles, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby-server/plugins/OpenSubtitles.dll Any idea what could have gone wrong? Thanks! Edited March 4, 2019 by adilei
Luke 42246 Posted March 4, 2019 Posted March 4, 2019 You may want to consider going backwards with mono releases in case that might help.
adilei 0 Posted March 4, 2019 Posted March 4, 2019 Hi, is that all that appears in the server log? I've tried to run emby using command line and got this: Unhandled Exception: System.DllNotFoundException: libembysqlite3.so.0 Could this be the issue?
adilei 0 Posted March 4, 2019 Posted March 4, 2019 You may want to consider going backwards with mono releases in case that might help. Backwards to which version? Thanks!
Luke 42246 Posted March 4, 2019 Posted March 4, 2019 Well we are not actively testing mono on x86 anymore, but you could try 5.14, 5.10, 5.8, etc.
