Menissalt 17 Posted May 4, 2018 Posted May 4, 2018 (edited) Since updating both versions crash, requiring a manual process end, when just trying to browse my libraries and much of my content is missing. Log attached embyserver.txt Edited May 4, 2018 by Menissalt
Happy2Play 9802 Posted May 4, 2018 Posted May 4, 2018 Log not attached. Has a Library Scan completed?
Menissalt 17 Posted May 4, 2018 Author Posted May 4, 2018 For to hit "attach this file" after selecting it.I have scanned the Movies for new and updated to no effect but I'm running a full scan all now
Menissalt 17 Posted May 4, 2018 Author Posted May 4, 2018 Same behavior after full scan, stopped at the same line:"2018-05-04 15:25:21.216 Debug BaseItem: Query requires post-filtering due to CollapseBoxSetItems" embyserver.txt
Luke 42210 Posted May 4, 2018 Posted May 4, 2018 Looks like there are some references to the old install location: C:\Users\RivoTech\AppData\Roaming\MediaBrowser-Server\data Did you move the install folder at some point?
Menissalt 17 Posted May 4, 2018 Author Posted May 4, 2018 (edited) This was a fresh install with imported data from a previous machine. This was done some months ago.I've removed my movie folders form Emby settings, restarted Emby, and have added them again. Running a scan all again and will report back. Edited May 4, 2018 by Menissalt
Menissalt 17 Posted May 4, 2018 Author Posted May 4, 2018 Deleted my collections library and now everything loads fine. Guess I'll work on adding the collections again when I have some free time and see if it still works.
Happy2Play 9802 Posted May 4, 2018 Posted May 4, 2018 You have a conflict with MediaBrowser-Server and Emby-Server paths All playlists are broken Could not find a part of the path 'C:\Users\RivoTech\AppData\Roaming\MediaBrowser-Server\data\playlists\tran [playlist] Collections would have the same issue.
Happy2Play 9802 Posted May 4, 2018 Posted May 4, 2018 (edited) Deleted my collections library and now everything loads fine. Guess I'll work on adding the collections again when I have some free time and see if it still works. I bet the path listed in Libraries was actually wrong. I recently did a custom install and restore and remember having to manually update some of these path. Just recreate "Collections" "mixed content" and point to *\emby-serverdata\collections. Edited May 4, 2018 by Happy2Play
Menissalt 17 Posted May 5, 2018 Author Posted May 5, 2018 This only happened after the update. I found out it created and is now using the old mediabrowser folder
Happy2Play 9802 Posted May 5, 2018 Posted May 5, 2018 This only happened after the update. I found out it created and is now using the old mediabrowser folder But isn't, it is running in Emby-Server. 2018-05-04 16:06:59.739 Info Main: Application path: C:\Users\Rivotech\AppData\Roaming\Emby-Server\system\EmbyServer.dll
