extensive 20 Posted May 4, 2018 Posted May 4, 2018 So there is a nice feature with lets say music apps. Scenario listening to a music track phone call comes in, you answer app playing music track auto-pauses and lets you talk after phone conversations it auto resumes this is great the problem is, emby auto resumes no matter what! Bug/Scenario listening to a music track I pause the track, NOT auto paused phone call comes in, i answer hang up and emby auto resumes solution emby should not auto resume if the track was paused manually
extensive 20 Posted May 10, 2018 Author Posted May 10, 2018 (edited) just to add to this. this bug makes using emby to play music files practically unusable. listening to a podcast driving to work pause it when i get to work get a phone call from my wife, hang up podcast blares in front of all of my employees the quick view when you drag down the top bar in android doesn't even have a stop button so i can't stop it i have to go into the app, with 3-4 screen presses to stop it. now i have to go back to find the track i was on and play it later when i actually want to listen to it also to add i am a beta tester for the emby android app so let me know if you want me to test anything. Edited May 10, 2018 by extensive
Luke 42244 Posted May 10, 2018 Posted May 10, 2018 Please try again with the next release of the app, thanks.
extensive 20 Posted May 10, 2018 Author Posted May 10, 2018 Please try again with the next release of the app, thanks. anxiously awaiting. thanks so much for hearing me out about the bug.
Luke 42244 Posted May 30, 2018 Posted May 30, 2018 Not yet, we're still working on the next update to the app. Thanks.
extensive 20 Posted July 2, 2018 Author Posted July 2, 2018 Imagine this Go to gym, use wonderful envy to play some heavy music Come home and sit on couch to relax and watch a movie with your 4 year old daughter Wife calls, I answer on my watch because phone is in kitchen We hang up and BLAAAAAAAAAAAAA music starts playing I honestly cant believe this hasn't been fixed. It is a shame
Solution Luke 42244 Posted July 2, 2018 Solution Posted July 2, 2018 There's a new update in beta, can you try that? thanks. 1
DerrickM 23 Posted December 20, 2019 Posted December 20, 2019 Is there a setting to enable this? Every phone call stops my music without fail. Even if I deny the call. Then I have reopen emby and shuffle the playlist again.
Luke 42244 Posted December 20, 2019 Posted December 20, 2019 Is there a setting to enable this? Every phone call stops my music without fail. Even if I deny the call. Then I have reopen emby and shuffle the playlist again. @@DerrickM it sounds like you're asking about something different from this topic. So you want to prevent the media from pausing, is that correct?
DerrickM 23 Posted December 22, 2019 Posted December 22, 2019 Well, I was hoping it would pause if my phone rings but then resume after it either stops ringing or after I hang up if I've decided to answer.
Luke 42244 Posted December 22, 2019 Posted December 22, 2019 You're saying it does a complete stop instead of a pause?
DerrickM 23 Posted January 1, 2020 Posted January 1, 2020 @@Luke, precisely. If music is playing a call stops it every time. messages don't though. In fact, not only does the music not resume but it doesn't show in my notification panel either. I have to re-open the application. I couldn't find any settings for this though, is there a permission that i need to manually allow? I am on the beta btw.
