Tezza4x4 1 Posted May 4, 2018 Posted May 4, 2018 (edited) Since upgrading to 3.4 on Synology, my TV Guide has disappeared. I see some errors in the log file (attached) indicating a problem with the xmltv code.System.IO.FileNotFoundException: Could not load file or assembly 'Emby.XmlTv, Version=1.0.6604.28157, Culture=neutral, PublicKeyToken=null' or one of its dependencies. emby log.txt Edited May 4, 2018 by Tezza4x4
Luke 42241 Posted May 4, 2018 Posted May 4, 2018 Hi there, apologies for the disruption. I am looking into this. Thanks.
Luke 42241 Posted May 5, 2018 Posted May 5, 2018 hi @@Tezza4x4, apologies. I see the problem and it is only affecting the Synology builds right now. We'll get a new release out by Monday to address this. It may also be available on the beta channel prior to that. Thanks. 1
tcxoman 0 Posted May 8, 2018 Posted May 8, 2018 Luke, Got the notice that 3.4.1.0 is available for download, and to log onto DSM and update, but file is not available. BTW, guide is also broken for Xpenology version., tcxoman
Luke 42241 Posted May 8, 2018 Posted May 8, 2018 Luke, Got the notice that 3.4.1.0 is available for download, and to log onto DSM and update, but file is not available. BTW, guide is also broken for Xpenology version., tcxoman It may not be posted yet. Sometimes Synology will run a day or two behind. Thanks.
solabc16 379 Posted May 8, 2018 Posted May 8, 2018 Hello @@Tezza4x4, @@tcxoman The updated builds for Synology and XPEnology are on the way. If you let me know what hardware you’re running on, I’ll push those packages up the queue. Best - James
tcxoman 0 Posted May 8, 2018 Posted May 8, 2018 Thanks. I'm using a DS717+. Appreciate all your work. Wish I knew enough to contribute but I'm a hardware microwave type. Be happy to test on my hardware if it will help.
solabc16 379 Posted May 8, 2018 Posted May 8, 2018 Hello @@tcxoman Hopefully you've picked up the new build now, they will have have been available from early afternoon today (BST). Thanks for the offer, we do sometimes have hardware specific items we need to test - so always helpful. A lot of my early work was on the first generations of mobile network infrastructure, DCS-1800 & PCS-1900. Best - James
tcxoman 0 Posted May 9, 2018 Posted May 9, 2018 James, Thanks for the quick fix. It works great. My last job before retiring was designing precision ovenized oscillators (OCXO's) for 4GLTE towers. Jim aka tcxoman
Tezza4x4 1 Posted May 9, 2018 Author Posted May 9, 2018 HI James, Got the update today. TV Guide all working again. Thank you!
