SenatorIvy 18 Posted May 4, 2018 Posted May 4, 2018 Hello! I could have sworn the other day that it was possible to group multiple libraries together in the library view, but now I'm finding myself insane, as it doesn't seem to be the case. I've got an interesting layout that seems necessary for my wrestling. What was originally a Mixed Content single library called Wrestling I have reorganized into 3 separate libraries: Wrestling - Documentaries Wrestling - Shows Wrestling - Misc I would like these to appear in the main libraries list just as "Wrestling" with the sub-libraries then being listed when one enters the initial Wrestling library. Is this possible or am I nutty? Wrestling is an odd thing.
arche 177 Posted May 4, 2018 Posted May 4, 2018 I have a Wrestling library for a family member. I have sub categories (mixed content library), not sure if this is the same thing, but this is my layout WWE (main folder) | -----WWE (summer slam folder) -----WWE (wrestlemania folder) -----etc.. Each show in different sub categories for me. Not sure if this is what you are referring to.
ebr 16310 Posted May 4, 2018 Posted May 4, 2018 Hi. The setting is still there - all the way at the bottom of the "Home Screen" page in user display settings (click user icon).
SenatorIvy 18 Posted May 4, 2018 Author Posted May 4, 2018 Hi. The setting is still there - all the way at the bottom of the "Home Screen" page in user display settings (click user icon). That's where I saw it, thanks! However it seems to make new libraries of Movies and TV Shows out of the contents; is it possible to tag libraries and choose what the result gets named? I have a Wrestling library for a family member. I have sub categories (mixed content library), not sure if this is the same thing, but this is my layout WWE (main folder) | -----WWE (summer slam folder) -----WWE (wrestlemania folder) -----etc.. Each show in different sub categories for me. Not sure if this is what you are referring to. That's basically what I was doing previously but wanted the benefit of the TV show aspect ratio for the posters, as a mixed-media folder seems to use a wider AR for its thumbnail posters, so all the contents look stretched out and wonky when they have posters for them. If I can't choose specifics for a library set I might just go back to the single Wrestling library and have to cope with the bad poster size.
