woenk 62 Posted May 3, 2018 Posted May 3, 2018 did a fresh install with version 3.4.0.0 using the .deb on Ubuntu 17.10. so far a way better performance and less errors. Works fine over http, but https brings nothing thing I found in logs 2018-05-03 07:12:21.345 Info ServerManager: Loading Http Server 2018-05-03 07:12:21.370 Info HttpServer: Adding HttpListener prefix http://+:8096/2018-05-03 07:12:21.373 Info HttpServer: Adding HttpListener prefix https://+:8920/2018-05-03 07:12:21.750 Info HttpServer: HTTP GET http://192.168.1.12:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-03 07:12:21.856 Info HttpServer: HTTP Response 503 to 192.168.1.60. Time: 141ms. http://192.168.1.12:8096/emby/System/Info2018-05-03 07:12:22.300 Info HttpServer: HTTP GET http://192.168.1.12:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-03 07:12:22.308 Info HttpServer: HTTP Response 503 to 192.168.1.60. Time: 8ms. http://192.168.1.12:8096/emby/System/Info netstat -tupl brings Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name tcp 0 0 0.0.0.0:sunrpc 0.0.0.0:* LISTEN 551/rpcbind tcp 0 0 0.0.0.0:22260 0.0.0.0:* LISTEN 1069/sshd tcp 0 0 0.0.0.0:hostmon 0.0.0.0:* LISTEN 762/systemd-resolve tcp 0 0 0.0.0.0:40269 0.0.0.0:* LISTEN - tcp6 0 0 [::]:sunrpc [::]:* LISTEN 551/rpcbind tcp6 0 0 [::]:8920 [::]:* LISTEN 16673/EmbyServer tcp6 0 0 [::]:37531 [::]:* LISTEN - tcp6 0 0 [::]:8096 [::]:* LISTEN 16673/EmbyServer tcp6 0 0 [::]:hostmon [::]:* LISTEN 762/systemd-resolve udp 0 0 0.0.0.0:7359 0.0.0.0:* 16673/EmbyServer udp 0 0 0.0.0.0:hostmon 0.0.0.0:* 762/systemd-resolve udp 0 0 0.0.0.0:1900 0.0.0.0:* 16673/EmbyServer udp 0 0 localhost:domain 0.0.0.0:* 762/systemd-resolve udp 0 0 0.0.0.0:sunrpc 0.0.0.0:* 551/rpcbind udp 0 0 0.0.0.0:727 0.0.0.0:* 551/rpcbind udp 0 0 emby:37651 0.0.0.0:* 16673/EmbyServer udp 0 0 localhost:58300 0.0.0.0:* 16673/EmbyServer udp 0 0 0.0.0.0:48087 0.0.0.0:* 16673/EmbyServer udp6 0 0 [::]:hostmon [::]:* 762/systemd-resolve udp6 0 0 [::]:sunrpc [::]:* 551/rpcbind udp6 0 0 [::]:727 [::]:* 551/rpcbind first would think, that it is because IPv6 (which is deactivated), but then again http is working Could it be, that the new install is using the old certificate (did not do a purge before installing)?
Luke 42246 Posted May 3, 2018 Posted May 3, 2018 Hi, why do you feel that https isn't working? What happens when you try it?
woenk 62 Posted May 3, 2018 Author Posted May 3, 2018 absolutely nothing, says the server closed the connection in the browser. Dashboard even states that it is only server the http. Checked the advanced settings and if I set the setting to "secure connection mode required" it even states "To enable HTTPS for external connections, you will need to supply a trusted SSL certificate, such as Let's Encrypt.". Does that mean that the self signed certificates are not any more useable ?
woenk 62 Posted May 3, 2018 Author Posted May 3, 2018 Which also means I need to buy a domain right ? Because letsencrypt needs to either.connect to ports 80/443 (which I have used for VPN stuff on my firewall) or you must prove the ownership of the domain, which again is impossible if one is using ddns. Would really know the reason behind this, even a sefl signed encrypted connection is more secure than an absolutely unencrypted one.
Luke 42246 Posted May 3, 2018 Posted May 3, 2018 There's really a couple reasons. One being that a self signed cert won't work with all apps and in most cases there's no way for us to force it to work. Most devices will reject the self signed cert. Unfortunately no matter how much we try and warn users about that, it's just a constant source of "https not working" troubleshooting for us. However, even with that, we probably would have kept it except that we've moved from the mono runtime to the microsoft .net core runtime, and the APIs we were using before to create the self-signed certificate are no longer available, meaning we'd have to find a whole new day of doing it.
mastrmind11 722 Posted May 3, 2018 Posted May 3, 2018 Which also means I need to buy a domain right ? Because letsencrypt needs to either.connect to ports 80/443 (which I have used for VPN stuff on my firewall) or you must prove the ownership of the domain, which again is impossible if one is using ddns. Would really know the reason behind this, even a sefl signed encrypted connection is more secure than an absolutely unencrypted one. I'm using a ddns and letsencrypt and have 0 issues w/ it. The proof of domain ownership is that letsencrypt can reach your server via the dns name you provide.
neik 874 Posted May 3, 2018 Posted May 3, 2018 @@mastrmind11, I am using a Let's Encrypt and ddns as well but with newer versions than 3.2.70.0 and Emby for Kodi I get handshake problems, see -> https://emby.media/community/index.php?/topic/58411-ssl-handshake-and-occassional-playback-issue/&do=findComment&comment=571976 So, I was wondering what your setup looks like?!
woenk 62 Posted May 3, 2018 Author Posted May 3, 2018 I'm using a ddns and letsencrypt and have 0 issues w/ it. The proof of domain ownership is that letsencrypt can reach your server via the dns name you provide. As stated before, I can not use ports 80 and 443 because they are useded for something I really need. I really find it quite appalling that such a major change was not published. As long as there is not a built-in way for most of users to obtain a certificate easily this option is really BS. Most people will tell their friend "switch the port".... nope...really unprofessionell to not provide the means to get a halfway secure connection and instead forcing an unsecured one. pissed enough to get back to the recent version, repository is working at least and https is working
Luke 42246 Posted May 3, 2018 Posted May 3, 2018 Thanks for the feedback and apologies for the disruption.
mastrmind11 722 Posted May 3, 2018 Posted May 3, 2018 @@mastrmind11, I am using a Let's Encrypt and ddns as well but with newer versions than 3.2.70.0 and Emby for Kodi I get handshake problems, see -> https://emby.media/community/index.php?/topic/58411-ssl-handshake-and-occassional-playback-issue/&do=findComment&comment=571976 So, I was wondering what your setup looks like?! I don't use Kodi, sorry. 1
woenk 62 Posted June 15, 2018 Author Posted June 15, 2018 Just as a short feddback...got myself a domain and used Letsincrypt. Still a hassle for me to switch the port to Emby every 3 months and really not satisfied that the change was not mentioned in the changelogs (with big capital letters). And yes...more detailed changelogs with the releases would be very welcome On the PLUS side..this build is a great improvement concerning library scan...went down to 30 minutes with my setup, And on Ubuntu 18.04 it runs like a charm using less CPU and RAM
williamk15 0 Posted January 20, 2021 Posted January 20, 2021 (edited) I need help with https. I've got the domain set just fine. Port forwarded the 8920 port, installed certificates and all happy, except i have to use the local htttps port because the remote https will not responde. Server version is latest. Os win 7 sp 1, Local https 443 works Remote 8920 not listening Ive tries port forward to both but only local https will respond. Any advice? Edited January 20, 2021 by williamk15
Luke 42246 Posted January 20, 2021 Posted January 20, 2021 6 hours ago, williamk15 said: I need help with https. I've got the domain set just fine. Port forwarded the 8920 port, installed certificates and all happy, except i have to use the local htttps port because the remote https will not responde. Server version is latest. Os win 7 sp 1, Local https 443 works Remote 8920 not listening Ive tries port forward to both but only local https will respond. Any advice? Hi there, exactly what port forwarding did you setup?
mastrmind11 722 Posted January 20, 2021 Posted January 20, 2021 On 6/15/2018 at 1:04 PM, woenk said: Just as a short feddback...got myself a domain and used Letsincrypt. Still a hassle for me to switch the port to Emby every 3 months and really not satisfied that the change was not mentioned in the changelogs (with big capital letters). And yes...more detailed changelogs with the releases would be very welcome On the PLUS side..this build is a great improvement concerning library scan...went down to 30 minutes with my setup, And on Ubuntu 18.04 it runs like a charm using less CPU and RAM You can set up certbot and not have to worry about it. https://www.google.com/search?q=letsencrypt+renew+certbot&oq=letsencrypt+renew&aqs=chrome.2.0i457j0l3j0i395l6.4487j1j7&sourceid=chrome&ie=UTF-8 this still seems a bit strange, i've literally got this same setup with CF and have no issues. I'm guessing you jacked up the CF config somewhere but have no idea since I don't know what tutorial you followed. however, i will say, if you plan to use this externally on a regular basis, getting a domain vs using a DDNS is significantly cleaner and easier to maintain.
mastrmind11 722 Posted January 20, 2021 Posted January 20, 2021 7 hours ago, williamk15 said: I need help with https. I've got the domain set just fine. Port forwarded the 8920 port, installed certificates and all happy, except i have to use the local htttps port because the remote https will not responde. Server version is latest. Os win 7 sp 1, Local https 443 works Remote 8920 not listening Ive tries port forward to both but only local https will respond. Any advice? start a new thread, this isn't related to the OP
woenk 62 Posted January 25, 2021 Author Posted January 25, 2021 On 1/20/2021 at 9:44 PM, mastrmind11 said: You can set up certbot and not have to worry about it. https://www.google.com/search?q=letsencrypt+renew+certbot&oq=letsencrypt+renew&aqs=chrome.2.0i457j0l3j0i395l6.4487j1j7&sourceid=chrome&ie=UTF-8 this still seems a bit strange, i've literally got this same setup with CF and have no issues. I'm guessing you jacked up the CF config somewhere but have no idea since I don't know what tutorial you followed. however, i will say, if you plan to use this externally on a regular basis, getting a domain vs using a DDNS is significantly cleaner and easier to maintain. I have a certbot running, but the renewal via a TXT is not supported by most registrars. Also I do not like to have port 80 open all the time. No need for DDNS either, it's a fixed IP Another thing is that I have web protection acivated on my Sophos XG firewall, so I need to upload the certificate on the firewall as well (the old UTMs allow for automatic renewal).
Q-Droid 1011 Posted January 25, 2021 Posted January 25, 2021 I think you mean to say that certbot plug-ins for TXT renewal are not available for many registrars. You can still use the TXT method manually or if the registrar has an API then create or modify a plug-in to work with them. No need to switch ports when using TXT. You don't need to switch the Emby port. A simple temporary HTTP server can satisfy the certbot validation requirement. Spin up something for WAN port 80, run certbot, spin it down.
woenk 62 Posted January 25, 2021 Author Posted January 25, 2021 5 hours ago, Q-Droid said: I think you mean to say that certbot plug-ins for TXT renewal are not available for many registrars. You can still use the TXT method manually or if the registrar has an API then create or modify a plug-in to work with them. No need to switch ports when using TXT. You don't need to switch the Emby port. A simple temporary HTTP server can satisfy the certbot validation requirement. Spin up something for WAN port 80, run certbot, spin it down. You misunderstood, I have to open port 80 on my Emby VM in order to have the certbot running there update, not switching the port of Emby itself. Tried the TXT method, but did not work, almost looks like certbot ask for another entry every 3 months and even if it worked, I would still need to upload the cert to my firewall and set it manually there (unless I can find an automated way using the REST API of the firewall, but so far no one has done it).
