jonomite 29 Posted May 3, 2018 Posted May 3, 2018 (edited) I just upgraded to 3.4.0.0 and my in-home LAN IP isn't displaying. Instead, I see the MAC address associated with my server. Is this intended behavior? Sent from my Nexus 5X using Tapatalk Edited May 3, 2018 by jonomite
Luke 42210 Posted May 3, 2018 Posted May 3, 2018 Hi, it's not the mac address, it's likely an ipv6 address. Try restarting your server and see if it's still the same. 1
jonomite 29 Posted May 3, 2018 Author Posted May 3, 2018 Hi, it's not the mac address, it's likely an ipv6 address. Try restarting your server and see if it's still the same.Restarted server from the dashboard and that didn't seem to fix it. I then restarted my machine, and that seems to have done the trick. Thanks! Sent from my Nexus 5X using Tapatalk
Luke 42210 Posted May 3, 2018 Posted May 3, 2018 If it happens again, it's not really anything to worry about. It just means that when the server queried the system for network addresses it didn't find any ipv4 addresses.
PenkethBoy 2068 Posted May 3, 2018 Posted May 3, 2018 FWIW - just seen this for first time on my QNAP after updating to 3.4.0.0 i only use ipv4 it is a LACP (bonded) setup though of 4 network ports - but this did not happen on previous release/beta - and the setup has not changed for the last 18 months for LACP Not the end of the world
