Luke 42210 Posted May 5, 2018 Posted May 5, 2018 The new Emby version can't do ? The way you're wording this question makes it sound like there's some kind of limitation. If you want collections to be automatically created, then just install the plugin. That's the way it's always been.
Hjlfmir 15 Posted May 5, 2018 Posted May 5, 2018 Thanks, I understand the difference in Collection management betwen emby solo and the plugin. With this new version, are collections synced with "fast sync" ?
Luke 42210 Posted May 5, 2018 Posted May 5, 2018 With this new version, are collections synced with "fast sync" ? I'm pretty sure they always have been.
Hjlfmir 15 Posted May 5, 2018 Posted May 5, 2018 Run a manual sync by launching the emby for kodi add-on > manual sync The server doesn't generate events for boxsets so the add-on can't pick up on changes automatically Check out the FR: https://emby.media/c...ts-for-boxsets/ @@Angelblue05 told me that a manual sync has to be done for boxsets.
Deihnyx 0 Posted May 5, 2018 Posted May 5, 2018 Have you run a library scan? Yes I did. It's only doing it on some movies, they can't be associated... Is there a specific file that store the association data between the movies and their collections?
Luke 42210 Posted May 5, 2018 Posted May 5, 2018 Currently if a collection is empty you won't be able to see it. That's resolved for the next release. Thanks.
Angelblue05 4132 Posted May 5, 2018 Posted May 5, 2018 @@Angelblue05 told me that a manual sync has to be done for boxsets. You can just run a refresh boxset instead, now by launching the add-on. The server plugin also syncs your boxset updates, this has been fixed with Kodi companion v2.0.3.0. 1
Hjlfmir 15 Posted May 6, 2018 Posted May 6, 2018 Thanks for your answer, you're right, I use the refresh boxset option. I didn't noticed that the Kodi Companion replaced the old fast sync plugin.
EliteCube 6 Posted May 7, 2018 Posted May 7, 2018 How much longer for an update? it is 5 days ago ...
d00zah 152 Posted May 7, 2018 Posted May 7, 2018 How much longer for an update? it is 5 days ago ... https://github.com/MediaBrowser/Emby/releases/tag/3.4.1.0
EliteCube 6 Posted May 7, 2018 Posted May 7, 2018 (edited) Nice job! Now im happy Edited May 7, 2018 by Seimann
