Happy2Play 9806 Posted August 1, 2019 Author Posted August 1, 2019 I can only assume without logs the your TVDB fail and got the information from TMDB. https://www.themoviedb.org/tv/72292-the-inspector/season/1?language=en-US 1
dejavux2 47 Posted August 1, 2019 Posted August 1, 2019 (edited) If metadata has already been pulled for these episodes, will they update after they (TVDB) are finished? Or, will I have to pull them out and start over? Edited August 1, 2019 by dejavux2
dejavux2 47 Posted August 1, 2019 Posted August 1, 2019 I can only assume without logs the your TVDB fail and got the information from TMDB. https://www.themoviedb.org/tv/72292-the-inspector/season/1?language=en-US Ok, that looks like where they came from.
Happy2Play 9806 Posted August 1, 2019 Author Posted August 1, 2019 If metadata has already been pulled for these episodes, will they update after they are finished? Or, will I have to pull them out and start over? No as the information has already been imported for the episodes so you would have to Refresh Metadata-Replace all to get the information.
dejavux2 47 Posted August 1, 2019 Posted August 1, 2019 No as the information has already been imported for the episodes so you would have to Refresh Metadata-Replace all to get the information. Ok, thank you! What about the Playlists issue? They are gone. The folders and files are still there, but not showing anywhere. Should I start a new topic for this?
Happy2Play 9806 Posted August 1, 2019 Author Posted August 1, 2019 Ok, thank you! What about the Playlists issue? They are gone. The folders and files are still there, but not showing anywhere. Should I start a new topic for this? I would.
jankete 5 Posted August 1, 2019 Posted August 1, 2019 Is there anything I have to do beside beeing patient and wait for an Emby and/or plugin update?
CChris 59 Posted August 1, 2019 Posted August 1, 2019 @@CChris Hi, Today I've noticed that Emby isn't able to collect meta-information for some of the TV Shows I've recently added - or more detailed, for some seasons of a show. e.g.: I've started with importing Episodes for the Show Star Trek: The Next Generation and Star Trek: Discovery For the Next Generation, everything went fine for Season 1 to 3 With Season 4 I've had some issues with the DVD Disk, so I needed to skip some Episodes. All Episodes after this aren't recognized correctly... I have the following error in the Emby-Server: 2019-08-01 07:10:06.343 Info HttpServer: HTTP POST http://192.168.52.243:8096/emby/Items/9345/Refresh?Recursive=true&ImageRefreshMode=FullRefresh&MetadataRefreshMode=FullRefresh&ReplaceAllImages=false&ReplaceAllMetadata=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:68.0) Gecko/20100101 Firefox/68.02019-08-01 07:10:06.351 Info HttpServer: HTTP Response 204 to 192.168.52.254. Time: 8ms. http://192.168.52.243:8096/emby/Items/9345/Refresh?Recursive=true&ImageRefreshMode=FullRefresh&MetadataRefreshMode=FullRefresh&ReplaceAllImages=false&ReplaceAllMetadata=true2019-08-01 07:10:06.536 Debug App: Running MovieDbSeasonProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.062019-08-01 07:10:06.564 Debug App: Running SeasonNfoProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.062019-08-01 07:10:06.582 Debug XmlSerializer: Deserializing file /var/lib/emby/config/xbmcmetadata.xml2019-08-01 07:10:06.622 Debug ProviderManager: Saving /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06 to Nfo.2019-08-01 07:10:06.736 Debug XmlSerializer: Deserializing file /var/lib/emby/config/metadata.xml2019-08-01 07:10:07.007 Debug App: Running FFProbeProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E15 - Tapestry.mkv2019-08-01 07:10:07.026 Info MediaEncoder: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E15 - Tapestry.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data2019-08-01 07:10:07.032 Info MediaEncoder: ProcessRun 'ffprobe' Started.2019-08-01 07:10:07.060 Info MediaEncoder: ProcessRun 'ffprobe' Process exited with code 02019-08-01 07:10:07.151 Debug XmlSerializer: Deserializing file /var/lib/emby/config/opensubtitles.xml2019-08-01 07:10:07.190 Debug App: Running TvdbEpisodeProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E15 - Tapestry.mkv2019-08-01 07:10:07.205 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/71470/all/de.zip2019-08-01 07:10:07.682 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/71470/all/en.zip2019-08-01 07:10:07.990 Error App: Error in TheTVDB *** Error Report *** Version: 4.2.0.40 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.18.12 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetMetadata(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2019-08-01 07:10:07.991 Debug App: Running EpisodeNfoProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E15 - Tapestry.mkv2019-08-01 07:10:08.005 Debug ProviderManager: Saving /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E15 - Tapestry.mkv to Nfo.2019-08-01 07:10:08.048 Debug App: Running FFProbeProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E24 - Second Chances.mkv2019-08-01 07:10:08.048 Info MediaEncoder: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E24 - Second Chances.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data2019-08-01 07:10:08.055 Info MediaEncoder: ProcessRun 'ffprobe' Started.2019-08-01 07:10:08.083 Info MediaEncoder: ProcessRun 'ffprobe' Process exited with code 02019-08-01 07:10:08.085 Debug App: Running TvdbEpisodeProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E24 - Second Chances.mkv2019-08-01 07:10:08.085 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/71470/all/de.zip2019-08-01 07:10:08.320 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/71470/all/en.zip2019-08-01 07:10:08.742 Error App: Error in TheTVDB *** Error Report *** Version: 4.2.0.40 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.18.12 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetMetadata(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2019-08-01 07:10:08.742 Debug App: Running EpisodeNfoProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E24 - Second Chances.mkv2019-08-01 07:10:08.743 Debug ProviderManager: Saving /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E24 - Second Chances.mkv to Nfo.2019-08-01 07:10:08.771 Debug App: Running FFProbeProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E17 - Birthright (2).mkv2019-08-01 07:10:08.771 Info MediaEncoder: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E17 - Birthright (2).mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data2019-08-01 07:10:08.777 Info MediaEncoder: ProcessRun 'ffprobe' Started.2019-08-01 07:10:08.805 Info MediaEncoder: ProcessRun 'ffprobe' Process exited with code 02019-08-01 07:10:08.809 Debug App: Running TvdbEpisodeProvider for /volume2/media/video/tv-shows/Star Trek - The Next Generation (1987 - 1994)/season.06/S06E17 - Birthright (2).mkv2019-08-01 07:10:08.810 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/71470/all/de.zip2019-08-01 07:10:09.031 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/71470/all/en.zip2019-08-01 07:10:09.285 Info HttpServer: HTTP GET http://192.168.52.243:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:68.0) Gecko/20100101 Firefox/68.0 Also, the same for Star Trek Discovery ... I've had half of the Season 1 imported, and everything was fine - today, I wanted to do the rest, but all Episodes, I've just added can't be identified by emby. In the Admin Area, I just noticed, that yesterday evening the Plugin Tvdb was "installed"... I have some doubts, that it could be related to this... ?!
CChris 59 Posted August 1, 2019 Posted August 1, 2019 (edited) @@Luke, thanks!I've just noticed, that the links are providing an 404 error... :-(I will try to use another provider.Adding several other Providers in the Library settings, seemed to work fine.The interesting part is, that tvdb has worked for the last couple of days, when I've started with adding the Shows...When it stopped, it seemed to be around the same time, when the plugin was installed, as shown in my screenshot above.Also, I am a bit confused, that the plugin was not updated, since I thought, it was already installed. Edited August 1, 2019 by CChris
Happy2Play 9806 Posted August 1, 2019 Author Posted August 1, 2019 (edited) Update TVDB link urls are working again. edit they are working for Series but not episodes. But I don't believe that has been brought up on their forum. Posted request on their forum. Edited August 1, 2019 by Happy2Play 1
vdatanet 1619 Posted August 1, 2019 Posted August 1, 2019 @@vdatanet When I hit + to search for unmatched show, since last version (4.2.0.0) I don't get any results.
nonyhaha 4 Posted August 1, 2019 Posted August 1, 2019 (edited) Hello everybody @@nonyhaha! I just decided to install Emby after using plex for a few years now. I opted to do this because I am tuning my server with a brand new quadro p400 card and I am opting for a free option to hardware transcode. First thing I was able to see is that the android app and web interface are a lot faster than plex, which is a blast for me especially, having a few series on my server. I have read this topic and the latest changes these days to thetvdb, but I wanted to double check with you if my issue is general or it extends to some other aspects. I have a folder, named "Serii" which contains 53 folders with tv cartoon series. They are all named correctly, as per emby/plex guidlines. On the plex server, these have been indexed and populated a long time ago so pictures and organizing is all ok. On the emby server, it looks like metadata is being downloaded, nfo files and episode pics are being generated in the data folders of each season. All is in there except the show's picture and season's pictures are missing. When I try to identify each show, the search results in absolutely no answer. Even if I search by imdb id, tvdb id, or the name of the show. And, on top of that, only 4 shows have the pictures and I can also chose other pictures when going to edit them. (although some of the seasons are not displaying them) I really do not understand why these 4 shows are ok and the others are not... Should I do something differently? where should I start looking into this? Thanks! P.S. I tried manually downloading the images from thetvdb, naming them accordingly and putting them in the specific folder, and they show up in emby. Now I do not know why they do not download automatically. I also added a tv shows library, and it mixed up my Outer limits 1963 with the outer limits 1995. they all show up as one and at this moment I am trying to find out how to separate them... Edited August 1, 2019 by Luke
vdatanet 1619 Posted August 1, 2019 Posted August 1, 2019 In my case it stopped working when the plugin was updated.
Kodi_Newcomer 27 Posted August 1, 2019 Posted August 1, 2019 @@Kodi_Newcomer Whats going wrong here. I have some records waiting for auto organize, but all the time i tried it, the recordings are marked red. Also when i try it manual. Here in the log i have found some errors. Maybe there is a bug. For some days, it works good, what i can see. A movie was added manual by me over the auto organize and it works good. I think he has only problems with the series. Here a port from the log, the rest as attached file. 2019-08-01 02:44:04.624 Error ProviderManager: Error searching *** Error Report *** Version: 4.3.0.0 Command line: C:\Users\Media Portal\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/Media Portal/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: C:\Users\Media Portal\AppData\Roaming\Emby-Server Application directory: C:\Users\Media Portal\AppData\Roaming\Emby-Server\system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetSearchResults(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2019-08-01 02:44:04.625 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt6473344&Episode=16&Season=2 2019-08-01 02:44:04.716 Warn App: No provider metadata found for SEAL Team season 2 episode 16 Greet's embyserver.txt
Happy2Play 9806 Posted August 1, 2019 Author Posted August 1, 2019 (edited) Either TVDB is still updating/migrating or the api queries needs updating. As these return a 404 for Seal Team 2019-08-01 02:44:03.866 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/328686/all/de.zip 2019-08-01 02:44:04.332 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/328686/all/en.zip Edited August 1, 2019 by Happy2Play
pünktchen 1410 Posted August 1, 2019 Posted August 1, 2019 As v3 of the API is coming, maybe they are shuting down v1 with the ability to download zip files forever.
Luke 42218 Posted August 2, 2019 Posted August 2, 2019 It looks like things are starting to get restored.
Ponyo 22 Posted August 2, 2019 Posted August 2, 2019 (edited) Not sure if this is related but for a single series (Thunderbirds) Emby is not retrieving any data apart from the series information but episodes, images etc. are not retrieved. If I try to identify then the results window is just blank. The weird thing is that instead of using the TVDB ID I instead searched using the IMDB ID but that doesn't return any results either. For another series everything appears to be OK except for the next up part where titles show up as s1:e1 title instead of 1. title. Edit: The next up titles are messed up for all series with new episodes. Edited August 2, 2019 by Ponyo
gamezonline 2 Posted August 2, 2019 Posted August 2, 2019 (edited) @@gamezonline OS: linux (Qnap 64bit x86) Server: 4.2.0.40 Thetvdb Plugin: 1.0.17.0 Im getting a error when emby try's to download the covers from thetvdb 2019-08-02 02:22:38.405 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/79525/all/en.zip 2019-08-02 02:22:38.416 Error App: Error in TheTVDB *** Error Report *** Version: 4.2.0.40 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_x86_64.qpkg Operating system: Unix 4.14.24.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.NotSupportedException: System.NotSupportedException: Unknown header: 1148405077 at SharpCompress.Common.Zip.ZipHeaderFactory.ReadHeader(UInt32 headerBytes, BinaryReader reader, Boolean zip64) at SharpCompress.Common.Zip.StreamingZipHeaderFactory.ReadStreamHeader(Stream stream)+MoveNext() at SharpCompress.Readers.Zip.ZipReader.GetEntries(Stream stream)+MoveNext() at Emby.Server.Implementations.Archiving.ZipClient.ExtractAllFromZip(Stream source, String targetPath, Boolean overwriteExistingFiles) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetMetadata(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: SharpCompress Edit: Just upgraded to 4.3.0.0 and same error 2019-08-02 02:39:54.435 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/79525/all/en.zip 2019-08-02 02:39:54.446 Error App: Error in TheTVDB *** Error Report *** Version: 4.3.0.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffdetect /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffdetect -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_x86_64.qpkg Operating system: Unix 4.14.24.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/System.Private.CoreLib.dll Processor count: 8 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.NotSupportedException: System.NotSupportedException: Unknown header: 1148405077 at SharpCompress.Common.Zip.ZipHeaderFactory.ReadHeader(UInt32 headerBytes, BinaryReader reader, Boolean zip64) at SharpCompress.Common.Zip.StreamingZipHeaderFactory.ReadStreamHeader(Stream stream)+MoveNext() at SharpCompress.Readers.Zip.ZipReader.GetEntries(Stream stream)+MoveNext() at SharpCompress.Readers.IReaderExtensions.WriteAllToDirectory(IReader reader, String destinationDirectory, ExtractionOptions options) at Emby.Server.Implementations.Archiving.ZipClient.ExtractAllFromZip(Stream source, String targetPath, Boolean overwriteExistingFiles) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetMetadata(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: SharpCompress TargetSite: SharpCompress.Common.Zip.Headers.ZipHeader ReadHeader(UInt32, System.IO.BinaryReader, Boolean) log.txt Edited August 2, 2019 by Luke
arche 177 Posted August 2, 2019 Posted August 2, 2019 This is being discussed here: @@Happy2Play mentioned the error https://emby.media/community/index.php?/topic/58523-tvdb-changes/?p=770646
vdatanet 1619 Posted August 2, 2019 Posted August 2, 2019 It looks like things are starting to get restored. I still can't match episodes with Auto Organize. 1
Happy2Play 9806 Posted August 2, 2019 Author Posted August 2, 2019 Update TVDB link urls are working again. edit they are working for Series but not episodes. But I don't believe that has been brought up on their forum. Posted request on their forum. Episode links resolved.
jankete 5 Posted August 2, 2019 Posted August 2, 2019 It's still not working for AutoOrganize: 2019-08-02 11:18:02.532 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/350665/all/de.zip 2019-08-02 11:18:02.560 Error ProviderManager: Error searching *** Error Report *** Version: 4.2.0.40 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.55 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.NotSupportedException: System.NotSupportedException: Unknown header: 1148405077 at SharpCompress.Common.Zip.ZipHeaderFactory.ReadHeader(UInt32 headerBytes, BinaryReader reader, Boolean zip64) at SharpCompress.Common.Zip.StreamingZipHeaderFactory.ReadStreamHeader(Stream stream)+MoveNext() at SharpCompress.Readers.Zip.ZipReader.GetEntries(Stream stream)+MoveNext() at Emby.Server.Implementations.Archiving.ZipClient.ExtractAllFromZip(Stream source, String targetPath, Boolean overwriteExistingFiles) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetSearchResults(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken) Source: SharpCompress TargetSite: SharpCompress.Common.Zip.Headers.ZipHeader ReadHeader(UInt32, System.IO.BinaryReader, Boolean) 2019-08-02 11:18:02.560 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt7587890&Episode=18&Season=1 2019-08-02 11:18:02.591 Warn App: No provider metadata found for The Rookie season 1 episode 18 2019-08-02 11:18:02.594 Error HttpServer: Error processing request *** Error Report *** Version: 4.2.0.40 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.55 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: System.Exception: No provider metadata found for The Rookie season 1 episode 18 at Emby.AutoOrganize.Core.FileOrganizationService.PerformOrganization(EpisodeFileOrganizationRequest request) Source: Emby.AutoOrganize TargetSite: Void MoveNext() 1
snl1 1 Posted August 2, 2019 Posted August 2, 2019 It's still not working for AutoOrganize: 2019-08-02 11:18:02.532 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/350665/all/de.zip 2019-08-02 11:18:02.560 Error ProviderManager: Error searching *** Error Report *** Version: 4.2.0.40 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.55 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.NotSupportedException: System.NotSupportedException: Unknown header: 1148405077 at SharpCompress.Common.Zip.ZipHeaderFactory.ReadHeader(UInt32 headerBytes, BinaryReader reader, Boolean zip64) at SharpCompress.Common.Zip.StreamingZipHeaderFactory.ReadStreamHeader(Stream stream)+MoveNext() at SharpCompress.Readers.Zip.ZipReader.GetEntries(Stream stream)+MoveNext() at Emby.Server.Implementations.Archiving.ZipClient.ExtractAllFromZip(Stream source, String targetPath, Boolean overwriteExistingFiles) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, String saveAsMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.DownloadSeriesZip(String seriesId, String idType, String seriesName, Nullable`1 seriesYear, String seriesDataPath, Nullable`1 lastTvDbUpdateTime, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbSeriesProvider.EnsureSeriesInfo(Dictionary`2 seriesProviderIds, String seriesName, Nullable`1 seriesYear, String preferredMetadataLanguage, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetSearchResults(EpisodeInfo searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken) Source: SharpCompress TargetSite: SharpCompress.Common.Zip.Headers.ZipHeader ReadHeader(UInt32, System.IO.BinaryReader, Boolean) 2019-08-02 11:18:02.560 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&i=tt7587890&Episode=18&Season=1 2019-08-02 11:18:02.591 Warn App: No provider metadata found for The Rookie season 1 episode 18 2019-08-02 11:18:02.594 Error HttpServer: Error processing request *** Error Report *** Version: 4.2.0.40 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.55 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: System.Exception: No provider metadata found for The Rookie season 1 episode 18 at Emby.AutoOrganize.Core.FileOrganizationService.PerformOrganization(EpisodeFileOrganizationRequest request) Source: Emby.AutoOrganize TargetSite: Void MoveNext() can confirm the error still exists 1
