RSG2017 0 Posted April 30, 2018 Posted April 30, 2018 Hope who can give me an emby based on Ubuntu or Centos transcoding QSV hardware acceleration tutorial query a lot of tutorials are not done so to help! Text has Google translation if you have any errors please understand 希望谁能给我一个基于Ubuntu或者Centos的emby 转码 QSV 硬件加速的教程 查询了好多教程都没有弄好 所以来 求助 ! 文字有Google翻译如有错误请理解 Hope who can give me an emby based on Ubuntu or Centos transcoding QSV hardware acceleration tutorial query a lot of tutorials are not done so to help! Text has Google translation error please write
mastrmind11 722 Posted April 30, 2018 Posted April 30, 2018 Not going to find one since qsv doesn't work on Ubuntu or CentOS. Use VAAPI, which is supported and works well, and is well documented all over the internet.
RSG2017 0 Posted May 1, 2018 Author Posted May 1, 2018 Not going to find one since qsv doesn't work on Ubuntu or CentOS. Use VAAPI, which is supported and works well, and is well documented all over the internet. Can only use vaapi?
Luke 42245 Posted May 1, 2018 Posted May 1, 2018 With the next release NVENC will also be available, if you have supported hardware.
RSG2017 0 Posted May 2, 2018 Author Posted May 2, 2018 (edited) 如果您有支持的硬件,下一个版本NVENC也将可用。 已经在测试版中的nvenc效果不是很理想 Edited May 2, 2018 by RSG2017
RSG2017 0 Posted May 2, 2018 Author Posted May 2, 2018 嗨,你能否更详细地描述你的问题? 谢谢。 I previously used Ubuntu + gtx1050ti for video transcoding 4Khevc 10bit the effect is not very good Caton is only 30FPS so want to use QSV to try the effect
RSG2017 0 Posted May 2, 2018 Author Posted May 2, 2018 嗨,你能否更详细地描述你的问题? 谢谢。 Is it possible to provide emby qsv environment configuration tutorial under Windows? Thanks
Luke 42245 Posted May 2, 2018 Posted May 2, 2018 There isn't much to it other than make sure your hardware supports it, and then enable it in Emby. You should also make sure windows is up to date as well as your graphics drivers.
RSG2017 0 Posted May 2, 2018 Author Posted May 2, 2018 (edited) 除了确保您的硬件支持它,并没有太多的东西,然后在Emby中启用它。您还应该确保的Windows是最新的以及您的图形驱动程序。 我打开了QSV,但观看了日志似乎我没有使用GPU进行转码这是我的日志。 系统是Windows 10的最新版本该驱动程序是在2018年2月。该服务器使用测试版 Log.txt Edited May 2, 2018 by RSG2017
Luke 42245 Posted May 2, 2018 Posted May 2, 2018 我打开了QSV,但观看了日志似乎我没有使用GPU进行转码这是我的日志。 系统是Windows 10的最新版本该驱动程序是在2018年2月。该服务器使用测试版 你的硬件是否支持QSV? 你有什么GPU?
