Luke 42247 Posted July 30, 2018 Posted July 30, 2018 Yes explore the advanced hosting settings. To learn more, please check out our wiki: https://github.com/MediaBrowser/Wiki/wiki/Hosting%20Settings Thanks.
larsonDigital 7 Posted July 30, 2018 Posted July 30, 2018 Hi Luke, thanks again for all your help on this! I was able to successfully change the port numbers used and everything seems to be working both locally and remotely. Interesting thing though I didn't expect. After making the change, my thumbnail/picture for My Media Library "Music" disappeared (see attached). It use to be a collage of album covers and now it's just blank. Does that make any sense from just changing the port numbers? Does I need to refresh something, or just wait for it to come back? Thanks again Luke! James
larsonDigital 7 Posted July 31, 2018 Posted July 31, 2018 It now has a new one! It must have refreshed sometime last night. Do those Media Library thumbnail pics refresh/change periodically?
larsonDigital 7 Posted July 31, 2018 Posted July 31, 2018 Thanks again Luke! Did you see my last post about metadata over here?: https://emby.media/community/index.php?/topic/60779-best-fit-for-large-music-library/&do=findComment&comment=603695
redaktorn 24 Posted April 27, 2019 Posted April 27, 2019 Hi Luke, Could it be possible to make it easier for us users of Emby Server and build in support for Let's encrypt? A function that automatically download and update the certificate (which otherwise will expire in 90 days). This feature is available in many Routers but it does not solve the problem. Because there is no way to make a "path" pointing to where Router stores the file with certificate.
Luke 42247 Posted April 27, 2019 Posted April 27, 2019 We are looking at improving the ssl process, yes. Thanks.
Greggers 4 Posted May 1, 2019 Posted May 1, 2019 I first suggested this here: https://emby.media/community/index.php?/topic/54586-security-101-secure-connections/page-9&do=findComment&comment=572225 Could a complete guide to how to setup SSL with the emby server (Window, Mac...) be in the official wiki; it's all a bit fragmented currently and, I'm sure, quite off putting for non-technical folk moving from, say, plex – where SSL is all taken care of. There are probably a hundred and one methods, but if the wiki could focus on the recommended or preferred version that emby thinks best. Plus, it would make any solution slightly more official and give peace of mind, as opposed to finding a solution via the forums. This would need to be step-by-step with visual aids also. And address points (how-tos) for renewing SSL certificates etc. Yep, I still do believe that emby should fold all this SSL business into Emby Connect, and including the fee into the premium membership or as an add-on. I love the flexibility of emby but have never really moved over from plex because of the ease-of-use factor. Good idea, I found it fairly straightforward but I didn't get bogged down with Letsenrypt, I'm sure it's probably not too difficult but I just bought a domain and added on an SSL cert for about £2 and all sorted!
redaktorn 24 Posted May 2, 2019 Posted May 2, 2019 Thanks, Looking forward to any coming improvements
fachizel90 0 Posted May 3, 2019 Posted May 3, 2019 (edited) If anyone is interested in using letsencrypt as a docker this guide is very useful. For emby the last few steps are different but can be found in the sample .conf files. I am using the duckdns docker container with it and have a few free subdomains. Works fine. Edited May 3, 2019 by fachizel90
Lane03 14 Posted June 5, 2019 Posted June 5, 2019 Not a fan of Plex, but their method for automatically providing certs to everyone is pretty clever. https://blog.filippo.io/how-plex-is-doing-https-for-all-its-users/
hugo0814 0 Posted February 15, 2020 Posted February 15, 2020 I've been following this tutorial "Let's Encrypt, Emby Server, and Windows", except I skipped Step 4.8-4.13 because I think Emby Server can handle PFX files with passwords now (please correct me if I'm wrong). I used a subdomain of my main domain, created a new "website" for it in IIS Manager called "Emby," created another Let's Encrypt SSL Certificate via CertifyTheWeb app, and plugged the resulting file/info into Emby Server. External Domain: media.<mydomain>.com SSL Certificate Path: <...>\SSLcertEmby.pfx Password: <PFX file password> Secure Connection: Required for all remote connections I restarted the Emby Server and the Dashboard reports Remote (WAN) access: https://media.<mydomain>.com:8920/. Everything seemed to go well, but I can't access the site. Can you think of anything I might have missed? Just have to say THANK YOU, sir! That link you provided finally ended hours upon hours of tries to get this to work. Now I finally got everything to work. Thanks again.
larsonDigital 7 Posted February 16, 2020 Posted February 16, 2020 Just have to say THANK YOU, sir! That link you provided finally ended hours upon hours of tries to get this to work. Now I finally got everything to work. Thanks again. Thank you for letting me know; always good to know when something helps somebody.
mcoyle76 2 Posted March 19, 2020 Posted March 19, 2020 (edited) @@larsonDigital when you setup the cert, and everything up on your windows server, do you have to have a static IP from your ISP? or anyone can answer this. Edited March 19, 2020 by mcoyle76
denz 501 Posted March 20, 2020 Posted March 20, 2020 (edited) This is how I went about it got a free domain name from here Securepoint DynDNS then there was a sale few weeks someone posted about the sale from ssls. Then you have to download a file to prove that it is your domain so downloaded a python web server copied the file that they wanted few minutes later it was authenticated and got my ssl certificate then had to import it into windows mmc certificate authority and then export it and let emby know the location and then close 8096 port and close port 80 and open 8920. Edited March 20, 2020 by denz
