ddurdle 75 Posted April 29, 2018 Posted April 29, 2018 Is there a way to change the quality settings? In the Roku app, there is a *Options where you can set the video playback quality (video bit rate limit). Is there an equivalent in the iOS Emby or iOS Emby Beta app? My video bit rate seems to be set really low. http://***:8096/emby/videos/67f83bf8a80deb1f5ced46a69fc59b38/hls1/main/0.ts?DeviceId=d02f9234481e2eddd044fafc7b8a9026e779c8d7&MediaSourceId=67f83bf8a80deb1f5ced46a69fc59b38&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=1&VideoBitrate=608000&AudioBitrate=192000&PlaySessionId=b5d964bc212c46d6988e0fab76629b18&api_key=de1a0218bb3a461ab66226acf880e80a&TranscodingMaxAudioChannels=2&RequireAvc=true&Tag=5415f9b2624f1cb7a202845a9a60adb7&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerBitrateExceedsLimit&allowVideoStreamCopy=false
Luke 42243 Posted April 29, 2018 Posted April 29, 2018 Yes, explore the settings in the app, and/or during video playback.
ddurdle 75 Posted April 29, 2018 Author Posted April 29, 2018 (edited) Yes, explore the settings in the app, and/or during video playback. I think the issue is I have video encoding disabled on the server so the setting-nut to change the transcoding type does not appear. I can see from the server log, the server believes the device can only handle a bitrate of 608000 (which is insanely low), so it invokes ffmpeg to transcode on any of my videos, say perhaps one with bitrate of 2200000. So it ends up DirectStreaming at the video bitrate of 2200000. I know the iOS device can easily handle 8200000+ bitrates because I can playback this content through Safari and Chrome on it. If the user has video encoding disabled on their profile, the correct behaviour should not necessarily be that the video is automatically then DirectStreamed to the user, because doing so is not benefiting the user in any way -- the bitrate to the user remains the same. Ideally the quality setting should be selectable if the server has disabled video encoding disabled so that the user can define their preference and then anything attempted to be played back that exceeds that should generate the "playback not possible because of no compatible streams". EDIT: If I enable the video encoding for the user, then the dropdowns for quality show up in profile playback settings. I can then disable video encoding after the preference is selected. Edited April 29, 2018 by ddurdle
Luke 42243 Posted April 29, 2018 Posted April 29, 2018 I think the issue is I have video encoding disabled on the server so the setting-nut to change the transcoding type does not appear. Correct. If you disable this then there will never be any transcoding, therefore there's no point in showing quality selections. If I enable the video encoding for the user, then the dropdowns for quality show up in profile playback settings. I can then disable video encoding after the preference is selected. If you have it disabled, then whatever quality you picked before won't matter.
ddurdle 75 Posted April 29, 2018 Author Posted April 29, 2018 Correct. If you disable this then there will never be any transcoding, therefore there's no point in showing quality selections. If you have it disabled, then whatever quality you picked before won't matter. If you have never picked a value, it's 600000 on iOS. And any video with a higher bitrate, it tries to DirectStream citing ContainerBitrateExceedsLimit By enabling video encoding, changing my default, and disable video encoding, now when I playback the same video, it uses the new default value to compare to the video.
Luke 42243 Posted April 29, 2018 Posted April 29, 2018 I think you're missing the point. When you disable video transcoding, it doesn't use that value at all and will just try to force the direct play.
ddurdle 75 Posted April 30, 2018 Author Posted April 30, 2018 Ok, I'll leave the video encoding parameter enabled. Can you help me understand why even with the parameter enabled and a maximum bit rate settings > the bitrate of the video that it still indicates ContainerBitrateExceedsLimit ? I've attached the embyserver.txt log and the ffmpeg log. It insists on DirectStream because "ContainerBitrateExceedsLimit" as opposed to DirectPlay. Thoughts on why this is happening? Thanks for your time. Your assistance will help me understand the issue so that I can help other users whom are running similar setup and running into the same issue. ffmpeg-directstream-58b63a0f-5388-4a48-911f-13345a67a946.txt embyserver.txt
Luke 42243 Posted April 30, 2018 Posted April 30, 2018 I think this one probably tried to direct play, has an error and then automatically switched to converting the audio. When this switch happens currently the reported transcoding reasons may be a little off.
ddurdle 75 Posted April 30, 2018 Author Posted April 30, 2018 I think this one probably tried to direct play, has an error and then automatically switched to converting the audio. When this switch happens currently the reported transcoding reasons may be a little off. I believe you are right. I've been playing around with this for past 3 days with various media types to figure out what's going on. At a few points, I'd have the dashboard open while I do the test with the iOS device, and I'll see the user popup in the dashboard with very briefly (blink of an eye) "Direct Playing" before it changes to "Direct Streaming". Is there anything I can play around with on the device to get some further insight? I've been testing with both the Emby and Emby Beta.
ddurdle 75 Posted April 30, 2018 Author Posted April 30, 2018 Further clarification -- this ContainerBitrateExceedsLimit this that is causing this media to playback with Direct Streaming instead of Direct Play is only happening when playing back with the Emby / Emby Beta iOS app. In chrome or Safari on iOS the same media does Direct Play.
Luke 42243 Posted April 30, 2018 Posted April 30, 2018 Further clarification -- this ContainerBitrateExceedsLimit this that is causing this media to playback with Direct Streaming instead of Direct Play is only happening when playing back with the Emby / Emby Beta iOS app. In chrome or Safari on iOS the same media does Direct Play. It's not causing anything, it's just an incorrect message displayed when the app has to switch from direct play to some other method.
ddurdle 75 Posted May 2, 2018 Author Posted May 2, 2018 I tested again on an ipad with an older install of the Emby (non-beta) app. I see the quality preference selection (even when video encoding is disabled for the user), and it direct plays instead of direct stream. So in a nutshell, it works perfectly as expected on both aspects. So the issue is either new iOS apps or specific to iOS phone app.
Dinklegeta 0 Posted May 9, 2018 Posted May 9, 2018 Just to back ddurdle here a bit, I've encountered a similar issue on android. I have an old version of the emby app (8 months old) that shows the quality settings in the playback area. On the new app it's not displayed and therefore seems to be using direct stream rather than play. This is using the server ddurdle has setup. Thanks.
Luke 42243 Posted May 9, 2018 Posted May 9, 2018 There is no problem here. I think you are perceiving a problem but there is no actual problem. If user transcoding is disabled on the server then playback will always be direct, it doesn't matter what the quality setting was before.
ddurdle 75 Posted May 9, 2018 Author Posted May 9, 2018 Luke, the problem is that Direct Play DOES NOT work whatsoever on newer versions of the android or ios apps. Whenever the criteria is met that it should use Direct Play, it drops down to Direct Stream and indicates a false reason such as ContainerBitrateExceedsLimit . On prior versions of the app, it will Direct Play with the exact same http link. Dinklegeta is not asking to transcode. He just references that the device he tested where it does work (Direct Play) is on a device that hasn't been updated for a while -- a device running a version of the android app that presents the quality selection selector even when video and audio transcoding is disabled on that user account on the server end. I also noticed the same when testing on an ipad that wasn't updated for a while -- it has the quality selector. The core issue is that new versions of emby on android and ios are suffering a condition that prevents Direct Play when playing back with a HTTP link -- it drops down to Direct Stream. Direct Stream has some issues seeking within the playback so users prefer Direct Play whenever possible.
Luke 42243 Posted May 10, 2018 Posted May 10, 2018 I think it is the same answer as what you asked in your other topic: https://emby.media/community/index.php?/topic/58821-emby-beta-for-roku-wont-direct-play/?p=576342 Thanks.
