woenk 62 Posted April 28, 2018 Posted April 28, 2018 ..somewhere in tha last relases it seems that by default Emby downloads subtitles which slows down the scanning process. I have deactivated the the automatic download and do the scan from timt to time manually. Also it seems that even though the download should be done via https://api.opensubtitles.org/xml-rpc Emby tries http://api.thesubdb.com/ 2018-04-28 07:02:52.752 Info HttpClient: HttpClientManager POST: https://api.opensubtitles.org/xml-rpc2018-04-28 07:02:52.840 Info HttpClient: HttpClientManager GET: http://api.thesubdb.com/?action=search&hash=0FB437BE4156EAEC4FFD3B45B68A3E1E2018-04-28 07:02:52.950 Error HttpClient: Error ProtocolError getting response from http://api.thesubdb.com/?action=search&hash=0FB437BE4156EAEC4FFD3B45B68A3E1E *** Error Report *** Version: 3.3.1.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.15.0.20 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Tue May 2 22:26:35 UTC 2017) Processor count: 6 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.Net.WebException: The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5641e4edad4f4464ba58c620a7b8ea48>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0
Luke 42245 Posted April 28, 2018 Posted April 28, 2018 It is using both. Subdb is moved to a plugin for the next release.
