shpitz461 4 Posted September 11, 2018 Posted September 11, 2018 I just moved to another state so my HTPC is in a box somewhere...
infinitereality 6 Posted September 11, 2018 Posted September 11, 2018 I'll give it a shot on mine when I get home.
SenatorIvy 18 Posted September 11, 2018 Author Posted September 11, 2018 Does it work? I mean sure an app that hides the mouse cursor after a period of inactivity will probably work but the issue is that Emby Theater isn't doing it. I assume this is because the call to hide the mousepointer fires after a mouse event and never again until another mouse event. Wouldn't the fix be to just re-call whatever sub hides the mousepointer on media-change? 1
infinitereality 6 Posted September 24, 2018 Posted September 24, 2018 I tried the program over the weekend and works like you'd expect. I'll keep using it, just one less thing I have to do when I first turn on the movie room equipment.
Wilky13 21 Posted September 24, 2018 Posted September 24, 2018 I tried the program over the weekend and works like you'd expect. I'll keep using it, just one less thing I have to do when I first turn on the movie room equipment. How long you been using it? Any bugs or quirks? Wish the mouse auto hid when starting ET via remote. Sent from my iPad using Tapatalk
infinitereality 6 Posted September 25, 2018 Posted September 25, 2018 I've been using it for a couple of days so far, but it does exactly as intended. And yes it does auto hide the mouse when starting ET via remote. Also the remote scrolling around in ET doesn't make it come back. There's a few options, like start with windows, set the timer delay to whatever you want, minimize it to the task bar and a few others. Definitely recommend checking it out How long you been using it? Any bugs or quirks? Wish the mouse auto hid when starting ET via remote.Sent from my iPad using Tapatalk 1
shpitz461 4 Posted September 25, 2018 Posted September 25, 2018 Luke, would it be possible for ET on Windows to nudge the mouse a little (a pixel or two) upon launch? For me, ever since v2.9.6 or so i've had the cursor issue, using strictly a remote. In my case ET is only app running and the computer is never rebooted or goes to sleep.
infinitereality 6 Posted September 25, 2018 Posted September 25, 2018 In my case ET is only app running and the computer is never rebooted or goes to sleep. Same with mine too.
Luke 42242 Posted September 25, 2018 Posted September 25, 2018 We already do that as a hack, but the app needs to be starting full screen for it to work.
Wilky13 21 Posted September 25, 2018 Posted September 25, 2018 (edited) We already do that as a hack, but the app needs to be starting full screen for it to work.Hmmm... [emoji848]. I have ET start full screen, but the mouse never moves nor disappears until I manually move it. Is it in the stable release or only beta where the hack is implemented? Sent from my iPhone using Tapatalk Edited September 25, 2018 by Wilky13
Luke 42242 Posted September 25, 2018 Posted September 25, 2018 We've had it for a long time. It works just fine in my testing. And I can verify this because if I remove the hack, then i do see the problem of not having focus until you click into the window.
shpitz461 4 Posted September 25, 2018 Posted September 25, 2018 I'm also running ET maximized. This is so bizarre, ET was fine back in v2.9.6 iirc. Did anything substantial change in terms of the overlays/visuals?
Wilky13 21 Posted September 25, 2018 Posted September 25, 2018 We've had it for a long time. It works just fine in my testing. And I can verify this because if I remove the hack, then i do see the problem of not having focus until you click into the window. It must be because I open ET through a script that minimizes WMC and then opens ET full screen. And when I exit ET it remaximizes WMC. Sent from my iPhone using Tapatalk
Luke 42242 Posted September 25, 2018 Posted September 25, 2018 Probably something related to that, yes.
snapwing 1 Posted September 26, 2018 Posted September 26, 2018 Yet I can verify what others have reported. In my case I also use a Harmony remote to launch ET maximized. Is this a common thread among those affected? Maybe something with how I'm launching ET in my Harmony activity?? The PC never sleeps or shuts down. When the TV shuts off, ET is closed. Once the TV and AVR power on, I hit a button to launch a fresh instance of ET. It used to work fine and the mouse would disappear after a moment of inactivity. Now it no longer works. The remote's programming hasn't changed. I just installed that auto mouse hiding utility mentioned above and while it works for now, it's pretty cheesy. Sent from my Pixel using Tapatalk 1
Guest asrequested Posted October 21, 2018 Posted October 21, 2018 Here's an idea for some of you guys. I'm about to order one of these remotes. It has a cursor button. https://www.amazon.com/gp/product/B0787Z1C2G/ref=ox_sc_act_title_1?smid=A1XNKS51HM8B0D&psc=1
Wilky13 21 Posted October 22, 2018 Posted October 22, 2018 Yet I can verify what others have reported. In my case I also use a Harmony remote to launch ET maximized. Is this a common thread among those affected? Maybe something with how I'm launching ET in my Harmony activity?? The PC never sleeps or shuts down. When the TV shuts off, ET is closed. Once the TV and AVR power on, I hit a button to launch a fresh instance of ET. It used to work fine and the mouse would disappear after a moment of inactivity. Now it no longer works. The remote's programming hasn't changed. I just installed that auto mouse hiding utility mentioned above and while it works for now, it's pretty cheesy. Sent from my Pixel using Tapatalk Same exact setup for me. Cursor used to hide, but at some point an Emby update broke it. Wish I had a better idea when it was, so we could point to which update to ET it was. Sent from my iPad using Tapatalk
khodges747 55 Posted October 22, 2018 Posted October 22, 2018 Yet I can verify what others have reported. In my case I also use a Harmony remote to launch ET maximized. Is this a common thread among those affected? Maybe something with how I'm launching ET in my Harmony activity?? The PC never sleeps or shuts down. When the TV shuts off, ET is closed. Once the TV and AVR power on, I hit a button to launch a fresh instance of ET. It used to work fine and the mouse would disappear after a moment of inactivity. Now it no longer works. The remote's programming hasn't changed. I just installed that auto mouse hiding utility mentioned above and while it works for now, it's pretty cheesy. Sent from my Pixel using Tapatalk I can verify this, too. Starting up, full screen, with the Harmony Elite remote (on Intel NUC, running Win 10 ver 1803, which never shuts down) and the cursor will remain visible until I move the mouse. I have a second system, using an ASUS laptop running Win 10 1803, on a different TV, using a different Harmony Smart Control remote, and the same behavior is observed. No other apps are running on either system, so I don't see what could steal focus. Both start full screen.
Raptor6L 29 Posted November 5, 2018 Posted November 5, 2018 It must be because I open ET through a script that minimizes WMC and then opens ET full screen. And when I exit ET it remaximizes WMC. Sent from my iPhone using Tapatalk I have the exact same set up, however for me it doesn't seem to matter whether Emby has been launched from within WMC or if it is launched separately with WMC closed, it will show up the mouse cursor and it needs to be pushed aside, most of the time. It appears to be a bit random as to whether it will be a problem or not. Interestingly, I was having a separate issue with Emby which resulted me in watching a few episodes using just the standard Win8.1 video player, and it wouldn't properly the mouse cursor for that either. It would disappear but then it would flicker so you keep catching a glimpse of where you left the mouse. I have the Microsoft MCE IR receiver, the Microsoft MCE keyboard (switched off and only comes out when needed) and a Harmony remote. A bit of testing I did earlier when the cursor wasn't hiding - if I pulled the usb plug for the receiver out, the cursor disappeared. Put the plug back in and it reappeared and wouldn't go away. Think I'm going to try that software mentioned earlier. Cheers Chris
shpitz461 4 Posted November 23, 2018 Posted November 23, 2018 The cursor issue is getting worse... Now on ET v3.0.5 it refuses to go away unless i actually move the mouse. My old trick of assigning alt-tab to a remote button and pressing the button twice upon ET launch doesn't work anymore. The OSD shows and hides but the cursor (regular pointy arrow, not a hand cursor) remains on the screen regardless of the OSD. Is there a way to have ET launch with the cursor hidden by default?
Luke 42242 Posted November 23, 2018 Posted November 23, 2018 I have not been able to reproduce this but am continuing to investigate. thanks.
shpitz461 4 Posted November 28, 2018 Posted November 28, 2018 Ha, I think it's fixed! The cursor (regular pointy cursor) appears upon launching of ET, but then it disappears after 2-3 seconds on it's own. I'll continue to monitor this issue and report back, need to try a few scenarios.
rikiwi 32 Posted November 28, 2018 Posted November 28, 2018 I wonder is this mouse behavior is related to the problem i'm having with version 3.0.5 as reported in this post. https://emby.media/community/index.php?/topic/65582-mouse-not-working-in-latest-version/ The mouse cursor remains even after the OSD has disappeared unless I move it off screen to the right or bottom. Just wondering.
Luke 42242 Posted November 28, 2018 Posted November 28, 2018 I wonder is this mouse behavior is related to the problem i'm having with version 3.0.5 as reported in this post. In that topic the issue is loss of mouse. You can't be having both right? https://emby.media/community/index.php?/topic/65582-mouse-not-working-in-latest-version/ The mouse cursor remains even after the OSD has disappeared unless I move it off screen to the right or bottom. Just wondering.
