Paul77nz 8 Posted April 26, 2018 Posted April 26, 2018 (edited) Is there a way I can move all my media to a different drive letter or folder without Emby scanning it all as new media? Thanks Edited April 26, 2018 by Paul77nz
Solution ebr 16310 Posted April 26, 2018 Solution Posted April 26, 2018 No, but if you save metadata and images with the media it should make that relatively painless. Also, I suggest some sort of drive pooling solution and then you'll never have this problem again . 1
Paul77nz 8 Posted April 27, 2018 Author Posted April 27, 2018 No, but if you save metadata and images with the media it should make that relatively painless. Also, I suggest some sort of drive pooling solution and then you'll never have this problem again . Thanks.
