vaise 340 Posted April 25, 2018 Posted April 25, 2018 I dont know if this is possible....... I would like it work tighter with emby to automatically create the TV Show folder name, and also create the Series X folder under The TV show folder, then do all its magic to move it into place. That would be the end of me needing to run Media Center Master to initially create the structure.
Luke 42253 Posted April 25, 2018 Posted April 25, 2018 We don't do this because the potential for incorrect matches is relatively high. 1
vaise 340 Posted April 27, 2018 Author Posted April 27, 2018 What about half of this then ? Just create the Season Folder ? i.e when the new season of a show starts, the auto organise cant do it. A bit of logic to check a Season folder is required maybe ?
Luke 42253 Posted April 27, 2018 Posted April 27, 2018 Well that it should already be doing. Perhaps it wasn't yet on tvdb at the time you tried to organize. How to report a problem. Thanks.
vaise 340 Posted April 27, 2018 Author Posted April 27, 2018 Cool - I notice a new season of elementary starts 1 May - i will not manually created the Season 6 folder and will see what it does. In the past it has not done that.
Luke 42253 Posted April 27, 2018 Posted April 27, 2018 It should create the season 6 folder. Perhaps it wasn't yet on tvdb at the time you tried to organize. How to report a problem. Thanks.
ernstgot 17 Posted May 12, 2018 Posted May 12, 2018 I for one would also love to see it if I download a high quality video it would update the old video in the folder. Because right now if a new one downloads it just sits there and I have to move it.
ernstgot 17 Posted May 13, 2018 Posted May 13, 2018 Could auto organize on the TV side work off of the folder name if we wanted it too?
