DungHo51 0 Posted April 25, 2018 Posted April 25, 2018 Hi, I'm a newbie, just found Emby a day ago and still in the learning process. I noticed that the delete media function within Emby will in fact delete content from Emby library as well as hard drive. Is there a way to prevent Emby from touching local hard drive. Another word, when I delete media from Emby it should only be deleted from Emby Library and not the hard drive. This is very important to me to be able to fully transition over to Emby.
Solution lorac 119 Posted April 25, 2018 Solution Posted April 25, 2018 I'm not sure how that would work as the media would just get picked back up on the next scan. You can prevent users from being able to delete media though in their user settings. Sent from my STV100-3 using Tapatalk 1
DungHo51 0 Posted April 25, 2018 Author Posted April 25, 2018 hi, Lorac, thanks for the reply, yes, user setting should work.
