BobbyDing 56 Posted April 24, 2018 Posted April 24, 2018 Hi Folks, I'm using the Docker version of Emby with Schedules Direct as my guideprovider. Recently one of the local channels went dark (they took the FCC buyout). That channel is gone from my Schedules Direct account, but Emby continues to show the channel without any data. It's taking up valuable real estate on screen. I've tried deleting Schedules Direct as the guide provider and re installing it, but the empty channel still appears. How do I remove this channel from the lineup in Emby? Thanks!!
Solution ebr 16337 Posted April 24, 2018 Solution Posted April 24, 2018 Hi. The guide doesn't determine what channels show up - the tuner does. So, you'll need to remove it from your tuner.
