KingKoopa08 17 Posted April 22, 2018 Posted April 22, 2018 I could use some help please. I have two of the exact same Rokus they are Roku Premier Plus that runs on gigabit internet connection wired. I have one device that constantly transcodes and one that direct streams. I checked all the connections and I get great speeds like 800-900+ down and up on each box. So I don't know how that is it. Would there be something I could do with codecs or something? Log attached!Thanks in advance.
Luke 42243 Posted April 22, 2018 Posted April 22, 2018 Hi there, we're happy to help. Can we please look at an example? Please attach the emby server and ffmpeg log for one and the other so that we can compare. you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Actually before you do this, please check your emby server dashboard during playback and it will tell you why it is transcoding. That is a great self-service way to find out on your own. If that doesn't satisfy you, then please provide the requested information. Thanks.
KingKoopa08 17 Posted April 23, 2018 Author Posted April 23, 2018 Thanks @@Luke, I checked and It looks like it might be a media format. That doesn't make a whole lot of sense since this is two of the same rokus. I have attached screenshots, server and transcode logs. server2.txt transcode 1.txt
ebr 16335 Posted April 23, 2018 Posted April 23, 2018 Check the playback settings in the app. The one that is transcoding is requesting a 3.5Mb/s max bitrate and the stream is 8.
KingKoopa08 17 Posted April 23, 2018 Author Posted April 23, 2018 @@ebr I am sorry I don't see anything talking about bit rate in the settings. Where would I change that setting?
KingKoopa08 17 Posted April 23, 2018 Author Posted April 23, 2018 @@ebr and @@Luke That did the trick! Thank you very much!
KingKoopa08 17 Posted April 23, 2018 Author Posted April 23, 2018 @@ebr is there a reason that automatic settings isn't picking that up?
ebr 16335 Posted April 23, 2018 Posted April 23, 2018 If the auto setting was coming up with that smaller number then it is possible that some bottleneck exists somewhere that will make video not play properly at a higher setting. The app tests the speed of communications with the server periodically and uses the results of that test to set the bitrate.
