Paul77nz 8 Posted April 21, 2018 Posted April 21, 2018 (edited) I have ripped some of my Blu-ray discs using MakeMKV, the video codec is reported as VC1 and they have DTS 5.1 audio; but when I play them Emby Theatre it is doing a full transcode of both the video and audio. The stated reason for the transcoding is "Audio codec not supported". However, if I switch to the commentary track on the same rip (which is in DD 2.0) the file direct plays with no transcoding. Why is Emby transcoding the video stream instead of just the audio? Also, I have several h264 MKVs with DTS 5.1 audio and they all direct stream in Emby Theater - so it seems to be a combination of VC1 with DTS. Edited April 21, 2018 by Paul77nz
Luke 42243 Posted April 21, 2018 Posted April 21, 2018 Hi there @@Paul77nz, can you please attach the emby server and ffmpeg log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Paul77nz 8 Posted April 22, 2018 Author Posted April 22, 2018 (edited) Hi there @@Paul77nz, can you please attach the emby server and ffmpeg log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. Hi @@Luke, EDITED: to supply better info. Attached are my server log and ffmpeg logs. Tested on the following 4 videos: Game of Thrones - s01e01 - Winter Is Coming.mkv Video: h264 Audio: DTS Result: Direct Stream (Remux) Battlestar Galactica - s01e02 - Water.mkv Video: VC1 Audio: DTS Result: Transcodes Battlestar Galactica - s01e03 - Bastille Day.mkv Video: VC1 Audio: DTS-MA Result: Transcodes Battlestar Galactica - s01e04 - Act of Contrition.mkv Video: VC1 Audio: DTS and Dolby Digital Result: Transcodes when DTS audio selected, immediately changes to Direct Play when audio switched to Dolby Digital. Thanks server-63660003331.txt ffmpeg-remux-9a615aa3-7b9b-452f-bf88-334f9e6fe7c1.txt ffmpeg-transcode-96b47825-6118-49a3-8404-8025c9d66c91.txt ffmpeg-transcode-70ea752f-ad31-4f56-a1cb-d7315876ee31.txt ffmpeg-transcode-771cafae-f350-4ecb-a8e3-eb89384a0eb3.txt Edited April 22, 2018 by Paul77nz
Paul77nz 8 Posted April 22, 2018 Author Posted April 22, 2018 FYI, same thing happens with Dolby TrueHD audio with VC1 video - forces full transcode.
Luke 42243 Posted April 22, 2018 Posted April 22, 2018 I will test to confirm but this is likely expected behavior. Anytime a conversion is needed we use the hls streaming protocol. I'm pretty sure vc1 cannot be used with hls and that's why we're also transcoding the video. 1
Paul77nz 8 Posted April 22, 2018 Author Posted April 22, 2018 I will test to confirm but this is likely expected behavior. Anytime a conversion is needed we use the hls streaming protocol. I'm pretty sure vc1 cannot be used with hls and that's why we're also transcoding the video. Thanks @@Luke, I'm not in a position to test at the moment, but will this also mean a full transcode for any VC1 videos with SRT subtitles?
Luke 42243 Posted April 22, 2018 Posted April 22, 2018 No because we can pull down srt subtitles separately.
Paul77nz 8 Posted April 22, 2018 Author Posted April 22, 2018 (edited) No because we can pull down srt subtitles separately. Thanks @@Luke, that at least means I don't need to go through the long and painful process of re-encoding everything to h264. I would have preferred if it transoded just the audio on-the-fly, but if that's not possible with VC1 I'll just have to convert all audio to Dolby Digital. However, I'll hold off on starting this until you can confirm that VC1 definitely doesn't support HLS - I don't want to do this and then discover it wasn't required after all! Thanks again for your help. Paul Edited April 22, 2018 by Paul77nz
Paul77nz 8 Posted April 25, 2018 Author Posted April 25, 2018 I will test to confirm but this is likely expected behavior. Anytime a conversion is needed we use the hls streaming protocol. I'm pretty sure vc1 cannot be used with hls and that's why we're also transcoding the video. Hi @@Luke, just wondering if you've had a chance to test and confirm that this is expected behaviour? Thanks
Solution Luke 42243 Posted April 26, 2018 Solution Posted April 26, 2018 Yes, I tried putting vc1 in the HLS streaming protocol and it would not play. 1
Paul77nz 8 Posted April 26, 2018 Author Posted April 26, 2018 Yes, I tried putting vc1 in the HLS streaming protocol and it would not play. Thanks @@Luke for confirming. I'll get started converting all my audio to standard AC3!
