thrlly 0 Posted April 18, 2018 Posted April 18, 2018 (edited) Why is the DB getting emtpyd without asking the user and without realtime monitoring when the mount loosing its connection only like 1minute? The DB file is still at the same size when the libary disappeared, but still it does start at 0 rescanning all the movies. Edited April 18, 2018 by thrlly
thrlly 0 Posted April 18, 2018 Author Posted April 18, 2018 I will write an script that kills emby as soon as the mount is lost until this has been "fixed"? but this is just an workaround. I paid like 6 months already for emby and i'm more than willing to pay more, but not for this current state, sorry When these problems (massive db problems with emby for kodi too) are "fixed?" i will pay again.
thrlly 0 Posted April 18, 2018 Author Posted April 18, 2018 Hi, what mount are you referring to? An network mount with libary files.
Luke 42210 Posted April 18, 2018 Posted April 18, 2018 Ok. This shouldn't happen anymore with the next release. Thanks.
psybertech 33 Posted April 19, 2018 Posted April 19, 2018 Ok. This shouldn't happen anymore with the next release. Thanks. That is GREAT news, Luke! I have a cron job that checks my mounts and only if they are live will it then run an Emby library update. I had to do that after a few issues I had while rebuilding my NAS (non-connectiviity and/or reboots) and forgot to disable my Emby scans since I had the time set low. Very cool that this won't be needed moving forward! Thanks! j
