SchnohneX 0 Posted April 17, 2018 Posted April 17, 2018 Good morning everybody, I have a very odd problem with my Emby installation. LiveTV works, DVR does not, Yes, I DO have Lifetime Premiere membership! Setup: AVM Fritzbox 6490 from Vodafone Germany with DVB-C officially enabled. Emby is running as an application (not service) in an account with admin rights on a Windows 10 (November 2017 Version) Pro machine. M3U Playlists created and verified - work perfect with VLC. I have all the channels in the guide. I have subscribed to guide data. Live TV works as it should. (Playback in Emby is sometimes pixelated as if sometimes dropouts happen, but that is secondary right now.) Scheduling (!) recordings also works well. But Emby never records anything. Looking into the gigantic log files it seems to be something regarding a Windows system (!) message that only http or https connections would be allowed. No files for the recordings seem to get opened or written, the directory stays empty. I tried different directories and directory formats. I tried directories in and outside of libraries. I searched the forums for the exact error message but got no hits. I read ALL messages that refer to the Fritzbox (not many) and got no clue. I saw some remarks regarding FFMPEG builds that do not support protocols and checked - no I am only running the build installed by the Emby installer itself. I checked rights, the user space Emby runs in does have read/write access to the location I want to store DVR files into. I don't get it. This either is something really obvious or really obscure. Emby does not post any error messages at all. It simply does not record anything and, as mentioned, I get only weird errors in the log. Everything else works fine. Any ideas for troubleshooting? Thanks and Grüße aus Deutschland, Boris
Luke 42245 Posted April 17, 2018 Posted April 17, 2018 Hi there, can we look at the server log from the time of a recording? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
SchnohneX 0 Posted April 17, 2018 Author Posted April 17, 2018 Luke, thanks - will post that Friday, won't be home before (and its not set up for remote access yet).
SchnohneX 0 Posted April 20, 2018 Author Posted April 20, 2018 Back again. Complete log included but this is the relevant passage I can't understand: 2018-04-20 09:28:00.974 Error App: Error recording to D:\emby-dvr\Schulfernsehen\Schulfernsehen 2018-04-20 - China - Volk und Staat.ts *** Error Report *** Version: 3.3.1.0 Command line: C:\Users\boris\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: C:\Users\boris\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\boris\AppData\Roaming\Emby-Server\system System.ArgumentException: Only 'http' and 'https' schemes are allowed. Parameter name: requestUri at System.Net.Http.HttpRequestMessage.InitializeValues(HttpMethod method, Uri requestUri) at System.Net.Http.HttpRequestMessage..ctor(HttpMethod method, String requestUri) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.GetRequest(HttpRequestOptions options, String method) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.DirectRecorder.<RecordFromMediaSource>d__7.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<RecordStream>d__94.MoveNext() System.ArgumentException at System.Net.Http.HttpRequestMessage.InitializeValues(HttpMethod method, Uri requestUri) at System.Net.Http.HttpRequestMessage..ctor(HttpMethod method, String requestUri) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.GetRequest(HttpRequestOptions options, String method) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.DirectRecorder.<RecordFromMediaSource>d__7.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<RecordStream>d__94.MoveNext() LOG.TXT
SchnohneX 0 Posted April 20, 2018 Author Posted April 20, 2018 Here is the .m3u as delivered by the tuner inside the fritz.box (the tvhd.txt file) and the version I edited (tvsd.txt) - Edit done to delete some channels and merge SD and HD and fritz.box delivers two seperate m3us for SH and HD... Thank you for looking into this! Boris tvsd.txt tvhd.txt
Luke 42245 Posted April 20, 2018 Posted April 20, 2018 Ok. Please try again with the next release of emby server, thanks.
SchnohneX 0 Posted April 20, 2018 Author Posted April 20, 2018 Will do - should I open it up for Beta releases to help you testing or stay on stable builds? Thank you for your kind answer! Grüße aus Deutschland, Boris
SchnohneX 0 Posted May 5, 2018 Author Posted May 5, 2018 I am extremely happy to announce that the latest server release fixed the recording problem. Will write a Wiki entry for the Fritz.Box setup Tuesday. Thank you, Emby Team, Thank you Luke!
Luke 42245 Posted May 20, 2019 Posted May 20, 2019 How did you manage to get a proper EPG? Hi there, are you having an issue, and if so can you please describe it? We are happy to help. Thanks !
bezibaerchen 0 Posted May 21, 2019 Posted May 21, 2019 Hey Like, thanks for stepping in. I just piggybacked on that thread as the OP managed to achieve what I'm looking for: Connecting his 6490 to Emby incl. EPG. I managed to get the channels and live video but am looking for his input to get hold of the EPG. As I struggled to find the suggested WiKi post I asked in here.
