hjason7812 35 Posted April 17, 2018 Posted April 17, 2018 I went into advanced to input ip address plus mask, to make it where emby will work with no internet for when my internet goes out which does a lot.. But when i did that and restarted emby, i get this when trying to go to the server (Input string was not in a correct format). How do i revert the setting back to defult without being able to log into the server?? Thanks
hjason7812 35 Posted April 17, 2018 Author Posted April 17, 2018 how can i find that if i can't log into emby
hjason7812 35 Posted April 17, 2018 Author Posted April 17, 2018 (edited) i have access to the jails folder, i looked through it but couldn't find the log folder. i found all kinds of log text files but they were what you want. where would it be at in the jails folder? Edited April 17, 2018 by hjason7812
Luke 42238 Posted April 17, 2018 Posted April 17, 2018 You can't even log in on localhost? that should always be possible.
