computerprep 149 Posted April 16, 2018 Posted April 16, 2018 When I configure the Trakt plugin settings for multiple users, whenever I click the Save button at the bottom of the settings page, the first drop-down menu always resets to my first alphabetical user. None of the checkboxes through the rest of the settings change... so it has led to mistaken settings multiple times. For example, I have two users... A and B. I can change A's settings and hit save, and everything looks right. Then I switch to B. Their settings are different, and it reflects the differences when I change the drop-down. However, when I click save for user B, whether or not I made any checkbox changes, the drop-down changes to A and still shows me user B's settings. Screenshots unfortunately won't help make this clearer. Try it for yourself. Hopefully it's not just me.
Luke 42253 Posted April 16, 2018 Posted April 16, 2018 Yea I think that's just because it does a reload after it saves and therefore everything gets refreshed.
computerprep 149 Posted April 16, 2018 Author Posted April 16, 2018 (edited) Totally makes sense... But not everything refreshes. Just the drop down. The save action should either refresh everything including checkboxes. Edited April 16, 2018 by computerprep
vaise 340 Posted May 21, 2018 Posted May 21, 2018 This has caught me out a few times, till I got used to it. However the number of times I have had to delete the trakt.xml file, then re-add the auth pin to the users lately has got so much that I have removed the plugin altogether now.
Luke 42253 Posted May 21, 2018 Posted May 21, 2018 The plugin is in process of being overhauled so we'll see what that brings. Thanks.
