Maintain LiveTv buffer when navigating away
Hi,
I would assume this is already on the list but as with MFC, if you are watching LiveTv and navigate away, say to check the guide, the currently watched channel would still be playing (could be a transparent background or a small liveTV window).
That way you could navigate back to the watched channel and not lose the buffer.
Thanks
