reggierat 18 Posted April 13, 2018 Posted April 13, 2018 In the attached log file i added Alien and Aliens, both movies were added to the Movies library using Fast Startup enabled but Box Sets did not update. Ran manual refresh and this forced the update Tested with another user as above Changed user and disabled Fast Startup and Box Sets updated as expected log-2018-04-13-21.27.49.zip
Angelblue05 4132 Posted April 14, 2018 Posted April 14, 2018 I will test on my side and let you know. Thank you for reporting. When you talk about the manual refresh, do you mean the refresh boxsets?
reggierat 18 Posted April 14, 2018 Author Posted April 14, 2018 I will test on my side and let you know. Thank you for reporting. When you talk about the manual refresh, do you mean the refresh boxsets? That's right, refresh Boxsets
Angelblue05 4132 Posted April 15, 2018 Posted April 15, 2018 The issue is part of the Kodi companion plugin. Looking into it. If Kodi is running at the time, it correctly gets the update. For some reason, the fast sync is not passing along the boxset update. 1
